It is currently Mon Feb 02, 2026 5:56 pm
 Post subject: Rear end and axel
PostPosted: Sat Jan 28, 2006 3:38 pm
i was wondering if an s-10 rear end will hold up to 260-300 hp? and also what will the stock axels in a 76 hold up to? if stronger are needed what is out there and is it a direct drop in? thanks.......the motor will be a GM350 also i want to run a manual 4-5 speed if possible? what is a tranny that will work other than an automatic?
PostPosted: Sun Jan 29, 2006 10:54 pm
this is one of the most common questions in this section, and a search or a quick browse over the last few pages could have most likely answered this question for you.
i am sure that a s10 rear will do just fine, i hear of many people running them with trucks that pull great times at the strip, but i have no experience myself. and about the tranny, the most commonly used is a hydramatic 350, or a th400. but i guess you could go with a muncie 4 spd
!!!FINALLY!!!
-1977 Luv mikado
PostPosted: Mon Jan 30, 2006 12:03 am
There are a few people on this site who have ran s10 rears with a mild v8. The C-Clips are the problem. If you put too much power behind them, they come apart.
ratnluv wrote:
I broke mine on the FIRST pass (before the blower or Nitrous) Axle came out (WHEEL,brake drum and most of the axle still atached!) Went past the 60 foot mark backwards, looking at the tree in the WRONG lane but was on a solo pass.
Michael Van Horn was running a stock rear with his.
michael van horn wrote:
383 stroker s.b.chevy, turbo 400 trans, 9.39 @ 70 mph in the 1/8th with stock rearend and spinning the tires all the way.
His photo gallery is at http://www.luvtruck.com/Gallery/Michael ... /index.htm
I guess the stock luv rear is a little stronger than we thought. :lol: If he had put some slicks on it, he would have been in trouble.
PostPosted: Mon Jan 30, 2006 2:11 am
Swap Specialist Mod
a friend of mine is using an s10 rear in his luv. hes got a 430hp 327 in front of it too. hes been using slicks on it, but he doesnt hook up all the great still. the rear in showing alot of signs of a fatigue though. the power has flexed the ring gear enough that it has touched the cover on the back and put a nice grove in it. its also been welded twice. the welds that we did the first time got chewd up, so we welded it again. hes managed to pull a 12.6 second 1/4 with it though. i still think that the rearend has an 11 in it though.
PostPosted: Tue Jan 31, 2006 9:26 am
hey just thought I would throw my 2 cents in the stock rear is pretty strong i ran the stock rear in my truck for one season (about 40 hard launches) i was running 6.80 consistent in the 1/8 (6.67) was the best run the stocker lasted longer than i thought but it did eventually break an axle but i have a dana in the works as long as you run street tires it would probably last a really long time
PostPosted: Fri Feb 03, 2006 1:37 am
Japanese Redneck
it will hold up fine for a while. I ran a stock 3.23 LS 10 bolt in my 4th gen LT1 Z28, 300 hp with a 150-200 shot and a stout shift kit , 2800 stall converter. it lived the whole time i owned the car with 2 years of subjecting it to severe duty (street racing every weekend on 26x10 slicks). A snappy shift kit is what will end it the fastest
and like luv junky says the stocker can take a beating too. I've never broke one with any of the mild motors i ran.
1978 LUV Truck 2WD
450 "Small Block" Chevy
3.70 Ford 9
28x10 Goodyears
