It is currently Sun Jun 28, 2026 3:21 am
Post new topic Reply to topic  [ 41 posts ]  Go to page Previous  1, 2, 3  Next
PostPosted: Fri Nov 11, 2005 9:43 pm
Thanks rezkid.
I got my luv to charging now, turns out I had a internal regulated alt. so I got one without it and now its charging.I got to drive it yesterday and Im using the stock rear but I dont know how much it can take.Is it okay for agressive street driving with the occasional burn out?
1975 V8 Luv
1980 Bagged Luv
PostPosted: Fri Nov 11, 2005 10:48 pm
I've seen some that lasted awhile and some not. but Id take it kinda easy for a while... :lol:
http://bonsaint.com/luvalbum2/index.htm
more pics of my 76 406ci 4 spd posi.
PostPosted: Tue Nov 15, 2005 9:35 pm
Is it wired like this?
Woops. Didn't see the second page.
PostPosted: Sat Dec 10, 2005 8:55 pm
I took some more photo's of the luv today. :D Enjoy!
1975 V8 Luv
1980 Bagged Luv
PostPosted: Sat Dec 10, 2005 9:42 pm
(in a cholo accent) Loooking goood man, loooking goood! 8) :roll:
PostPosted: Sat Dec 10, 2005 10:14 pm
Thanks.
1975 V8 Luv
1980 Bagged Luv
PostPosted: Sat Dec 10, 2005 11:21 pm
Swap Specialist Mod
thats sweet man. i really like your throttle cable. that looks just like something i would do. :D
PostPosted: Sat Dec 10, 2005 11:26 pm
It's custom lol :lol:
Thanks
1975 V8 Luv
1980 Bagged Luv
 Post subject: Stock Rear End
PostPosted: Sun Dec 11, 2005 11:59 pm
Stock will work for a while, but don't put any sticky tires on. S-10 rear ends are stronger, but a Ford nine inch is the best of the inexpensive. I had mine cut down for $120.00. It cost another $200.00 for axles from Moser.
PostPosted: Mon Dec 12, 2005 6:19 pm
I might be picking up a ford 9'' and a S-10 blazer rear tommorow.I'd like to get axles that have the same lug pattern 6x5 1/2 as the front.Can Moser get those axles for the 9''?
1975 V8 Luv
1980 Bagged Luv
PostPosted: Mon Dec 12, 2005 8:09 pm
mine is a ford 9 inch and was not cut down it is stock size and fits great :wink:
PostPosted: Mon Dec 12, 2005 9:13 pm
Truck is lookin really nice Dan 8O Keep it up!!!!!!!!!!!
PostPosted: Wed Dec 14, 2005 3:06 am
Thank you. :D
1975 V8 Luv
1980 Bagged Luv
PostPosted: Wed Dec 14, 2005 3:41 am
One thing you could add, is a nice 3inch cowl scoop for the hood 8)
PostPosted: Wed Dec 14, 2005 11:33 am
Moser can build any size axel and any bolt pattern you want. My axels are about 14 inches and drilled to a chevy 5 bolt patern. I would also add that moser has a great turn around time, just under a week.
PostPosted: Wed Dec 14, 2005 4:28 pm
Cool! Thanks.
I'm considering puttin' on a cowl hood to let out the heat out.Just got to find one for a good price. :?
1975 V8 Luv
1980 Bagged Luv
PostPosted: Wed Dec 14, 2005 9:50 pm
Swap Specialist Mod
i kinda like the stock hood look, but maybe like a 2 inch cowl with some 400 tags on the sides of it.
PostPosted: Fri Dec 16, 2005 9:55 pm
I have been watching ebay for the emblems, and damn, they want a friggin arm and a leg for em. So if anybody comes across some a a bone yard. PLEASE keep me in mind!!!!!!
PostPosted: Sat Jan 21, 2006 12:57 am
Well just an update on the luv........
I had to go to a 600 cfm cause the 750 was way too big for my cam.I'm finally putting on a real exhaust system(Force mufflers) ,and finishing up the interior.I know some of you heard about the ''Throwout bearing'' noise I had, and it turns out that I left a Vicegrip on one of my amplifier bolts and it was rubbing on my driveshaft.Every time I would have to brake hard to avoid hitting someone cause I couldn't help from hauling ass it would swing forward and grind on my driveshaft. :oops: So I guess it wasn't such a big deal.I'm still trying to get my water temp gauge to work it just stays in one spot.Are you guys using the old sender or a different one or not even using the gauge at all?Also does anybody know what the torque is on the stock rear pinion bolt cause mines loose?My rod knock isn't as bad now that I put some STP oil treatment in there.I guess the bearing was dry from the motor sitting for a couple months but IDK.
Just thought I'd give ya guys and girls a little update! :D
1975 V8 Luv
1980 Bagged Luv
PostPosted: Sat Jan 21, 2006 2:30 am
that's awesome man, I'll have to swing up there someday and check it out :)
2002 Lexus RX300
1998 Honda Accord
1977 Chevy Crew Cab Dually
1954 Ford F100
http://www.yvtruckclub.com/forum
Users browsing this forum: Majestic-12 [Bot] and 51 guests
