It is currently Wed May 27, 2026 8:03 am
 Post subject: Vacume question
PostPosted: Tue Jan 17, 2006 11:21 pm
Once again my tunnel ram is giving me more problems. I need to figure out how to get my tranny some vacume (TH 350). My intake doesnt have any vacume ports and my Carbs(2X Holley 4160) only have 1 direct vacume port. Also I will need more vacume for my distributor and my brake booster. I think I can live with out the brake booster but the trans and distributor are a must. I dont want to convert my transmission to full manual. Should I drill and tap a hole in the manifold? Other than that I dont know what I should do.
PostPosted: Tue Jan 17, 2006 11:28 pm
While reading your post, 1st thing I thought was to drill and tap, so I guess that would be my suggestion if you have the stuff to do it! Good luvk!!!!!!!!
PostPosted: Tue Jan 17, 2006 11:30 pm
Drilling and tapping shouldnt be a problem as far as doing it goes. Just finding the right place and figuring the right size.
PostPosted: Tue Jan 17, 2006 11:36 pm
Do it right infront of the dist., a little to the passenger side.And I wouldnt go no bigger than like the size if a sharpie!
PostPosted: Tue Jan 17, 2006 11:38 pm
There isnt any room between the dist. and the manifold I allready had to get rid of my HEI for clearance reasons. Vacume lines suck and they look ugly.
PostPosted: Tue Jan 17, 2006 11:41 pm
I mean in the manifold, just infront of your dist.
PostPosted: Tue Jan 17, 2006 11:44 pm
yeah I know what you meant I just didnt get it right away. I got alot of work to get done before April. Im probably not going to have everything done that I want to get done but I am going to try to make my truck at least driveable so I can make it.
PostPosted: Tue Jan 17, 2006 11:45 pm
scratch
PostPosted: Tue Jan 17, 2006 11:47 pm
well I see now :oops: If your running a tunnel ram then you would probably have to go at an angle. So just go below the back carb down some. I hope you do get it going before April too!!!!!
PostPosted: Tue Jan 17, 2006 11:48 pm
Have you ever tapped cast aluminum? Im wondering if its going to causeany problems like cracking.
PostPosted: Tue Jan 17, 2006 11:50 pm
I havn't, but I will ask one of our maintenance guys here at work. He has a race car, and knows a ton about it. So I will run this by him, and see what he suggest.
here is the picture
PostPosted: Wed Jan 18, 2006 12:05 am
I guess I could probably put spacers under my carb and drill and tap into one of those rather than drill into my manifold. Either route I go its still going to look like crap in my opinion.
PostPosted: Wed Jan 18, 2006 2:53 pm
Have you thought about runing a vacume pump from a deisle truck that is what i did with a 32 ford rod with duel carbs and a 9 inch tunnel ram i had all the vac. in the world after that
PostPosted: Wed Jan 18, 2006 4:27 pm
Yeah actually Bodyman mentioned doing that last night. I am not really excited about fabricating the brackets for that but I also kind of came up with a solution that if it works it will solve one more problem with my throttle linkage. Im thinking I am going to get a couple of carb spacers and just drill into the rear one.
PostPosted: Wed Jan 18, 2006 4:52 pm
that might work if your cam doesnt have alot of duration. i tried that on my rod but the duration was to big but good luck.
PostPosted: Wed Jan 18, 2006 5:05 pm
Just out of curiosity what would happen if I ran the distributor off of the direct direct vacuum port on the carb. If I remember right someone said it wouldnt work but I didnt get an explanation behind it.
PostPosted: Wed Jan 18, 2006 5:36 pm
if the dist. had vacume all the time it would be advanced all the time you could do away with the vacume to the dist. if you go to the parts store and get a dist. curve kit i comes with weights and lighter springs so you can make it advance at what ever rpm you want
PostPosted: Wed Jan 18, 2006 5:42 pm
Yeah I was thinking about that but I havent had a chance to check into it yet.
PostPosted: Fri Jan 20, 2006 12:27 pm
Hey Gabe depending on how radical the cam is in that motor, there may be no point in tapping into a vacuum source anyway. But you could run the vac advance off full manifold vacuum maybe.. I ran the dist in my nova with vac advance and I hated it.. it made my 60' times go in the toilet, and it causes a slight stumble, and with small tires i need all the "shock" I can put to the rear to make the suspension 'work' and hook the car..
So to make a long story short, you're only big concern is the vacuum booster for the brakes, and im not up on manual conversion stuff just yet. odds are i wont have any vacuum either to run the booster, so a manual conversion would be handy!
LUV Truck Desserter!
76 Daily driver (SOLD)
63 Nova
74 Camaro
Users browsing this forum: Google [Bot] and 12 guests
