It is currently Mon Jun 08, 2026 9:40 am
Post new topic Reply to topic  [ 69 posts ]  Go to page 1, 2, 3, 4  Next
 Post subject: stock temp
PostPosted: Wed Jan 04, 2006 11:03 pm
I need help I want to hock my stock temp gage back up where do the wires go to the intake
If you cant find it grind it
79 4x4 1.8 liter
69 Jeepster comando v6
PostPosted: Thu Jan 05, 2006 1:51 am
under side of the intake
PostPosted: Thu Jan 05, 2006 8:27 am
I know that is there any way some one could take a picture for me of it
79 4x4 1.8 liter
PostPosted: Thu Jan 05, 2006 9:47 am
You and your stupid pictures, if you know were the stupid thing is then why don't you hook it up? Why'd you take it off in the first place? Jeez! Go buy a manual for your truck so you can have a picture there, if it's anything like the diesel sending unit it should just be one little slip-on connector on the bottom of the intake. It's not that hard, unless you completely re-wired your whole guage sys. then you just kicked your own butt right there.
N0vv my k3yb04rd 15 m3551ng u9, by3!
PostPosted: Thu Jan 05, 2006 11:36 am
The sender is on the bottom of the intake, pretty much straight down from the thermostat housing (where the top rad hose goes in). Taking a picture of it would pretty much require pulling the motor, this is not one you can just see, you'll need to feel around. It will feel alot like a bolt, but the end of it is shaped sort of like the head of a nail. There is only one wire to it, and it slips over the nail head. Yellow with a black stripe is the wire color if I recall.
PostPosted: Thu Jan 05, 2006 5:24 pm
I no where its is I cant find the stupid plug so finalman shut up
79 4x4 1.8 liter
PostPosted: Thu Jan 05, 2006 9:01 pm
Then go to the auto parts store and buy one!
1975 V8 Luv
1980 Bagged Luv
PostPosted: Thu Jan 05, 2006 9:03 pm
Let's not turn this into a "no you shut up! No you shut up!!!" match, that's 3 year old crap, just hook up your stupid wire.
PostPosted: Thu Jan 05, 2006 9:34 pm
Can't we all just get along??
What the hell,SHUT UP
PostPosted: Thu Jan 05, 2006 9:39 pm
Swap Specialist Mod
wow, all you guys need to just calm down.
finalman, i think you need to stop your crap. just calm down and ignore him.
chavy, you need to calm down too. if he says somethin just dont listen to him
we dont need this crap on this site. im getting kinda tired of it. mkay? :)
PostPosted: Thu Jan 05, 2006 10:31 pm
ARE THESE THE WIRES
79 4x4 1.8 liter
PostPosted: Thu Jan 05, 2006 10:38 pm
See sig below....
Seriously chill... 800xl gave the best explanation that you're gonna get... I don't think anyone here can help any more than that.
:smt033 Image
PostPosted: Thu Jan 05, 2006 10:47 pm
Chavy, this is alittle more info for you above what 800 said.
Next to your coil(the thing that has a wire to the middle of the dist cap) there is a 4 wire plastic plug. 1 wire goes to the temp sender,1 to the oil sender and 1 to the dist. I do not know what the last one is for. No take all this info and go to the wiring schem in the info area of this site to get the color codes and hook them up. This is not rocket science, just follow the wiring schem.
EDIT:: I have done all your research for you. Like I said, there are 4 wires in that connecter by the coil
1. grn (green) goes to the A/C if equiped
2. blk/red (black wire with a red stripe) goes from the coil to the dist.
3. ylw (solid yellow) goes to the oil pressure sending unit
4. ylw/blk (yellow wire with a black stripe) goes to the coolant temp sensor
PostPosted: Thu Jan 05, 2006 11:25 pm
the coolant temp sender is located on the tremo right
79 4x4 1.8 liter
PostPosted: Thu Jan 05, 2006 11:32 pm
if you find the wire Luvrv8 mentioned, look for your sending unit and hook it up... it's pretty straightforward.
PostPosted: Thu Jan 05, 2006 11:38 pm
thats the thing I cant find the sending unet
79 4x4 1.8 liter
PostPosted: Thu Jan 05, 2006 11:47 pm
then you need to crawl under your truck and find a spot to shine a light up in that area and see if it's there or been plugged off.. if it's plugged, get a new one..
PostPosted: Thu Jan 05, 2006 11:50 pm
ok I think I found it if there wasn,t a sending unet there would be a hole that would go up in the intake
79 4x4 1.8 liter
PostPosted: Thu Jan 05, 2006 11:54 pm
there would be something in place of the sending unit if it wasn't there otherwise all your coolant would leak out a big hole. if you have aftermarket gauges then someone make have replaced the original with one for whatever gauges they installed.
PostPosted: Fri Jan 06, 2006 12:06 am
need to go to the junk yard and find out whats different thanks you guys for all your help I a going to get it working again one way or another
79 4x4 1.8 liter
