It is currently Sun Feb 01, 2026 2:24 pm
 Post subject: how to tell; 305 - 350
PostPosted: Wed Nov 02, 2005 2:20 pm
I got myself another chevy truck, not a luv though. It's a '79 1/2 2wd. Decent looking truck. But I have a question. . .Guy I bought it from says it has a 350, but a guy from work said it's only a 305 and I don't know enough about sbc's to tell the difference. I think I'm going to like this truck.
1980 Luv Mikado 4X4
PostPosted: Wed Nov 02, 2005 2:33 pm
Get the numbers off of the block and run them to be sure.
it may have come stock with something, then been swapped with something else.
never can tell unless you run the numbers....well im sure some of the more experienced people can tell the differance, but I would run the numbers.
03Cobra
PostPosted: Wed Nov 02, 2005 4:44 pm
Is there a difference in the firing order? And where on the block are the #'s?
1980 Luv Mikado 4X4
PostPosted: Thu Nov 03, 2005 6:56 am
All chevy small blocks have the same firing order.
the numbers should be beside the distributor on top of the engine.
look here http://www.mortec.com/location.htm
go here when you get your numbers http://www.mortec.com/castnum.htm
03Cobra
PostPosted: Mon Nov 07, 2005 11:29 am
3970010 So unless the engine is 10 years older than the truck, I've got a 350.
1980 Luv Mikado 4X4
PostPosted: Mon Nov 07, 2005 5:44 pm
From what I saw on Moser it would have to be a 350 unless it was made in 69, then it could be a 302 or 327. If you can find the block casting date that could clinch it, but odds are its a 350. Am I reading that right?
PostPosted: Mon Nov 07, 2005 8:58 pm
Yep, that's how I had it figured, being that the truck is a '79. . .minus ten years. . .='69. Cool thing is that it runs like glass. It has a Q-jet 4-bbl and a turbo 350 with 275/60r15 remington tires. I think the drive-train will still be going when the body rusts off, then I'll just find an old luv to put it in. :wink: For now though, it's my Purple People Eater.
1980 Luv Mikado 4X4
