It is currently Tue Mar 24, 2026 11:06 pm
 Post subject: sputtering sound
PostPosted: Fri Sep 09, 2005 10:45 pm
I was driving in the freeway when then engine began to sputter and eventually died. I had it towed home where I changed the cap and roter, but it still ran really rough and acted out of time. I changed the plugs and wires and that seemed to do the trick, but I have a loud sputtering sound coming from the engine. The truck still goes pretty good but the sound is driving me nuts. Any suggestions?
PostPosted: Sat Sep 10, 2005 1:12 am
Could be points. Seems like when they get bad they almost seem to do it all at once. It also could be timing.
Of course, can't rule out fuel problems. A little water in the gas would make it act like that. You may just need to run it, maybe add some gas dryer additive (99% Isopropyl rubbing alcohol works) and it could clear itself up. With fuel availability problems in recent weeks you might have gotten some from the bottom of a barrel somewhere.
