It is currently Fri Feb 06, 2026 2:50 am
PostPosted: Mon Aug 29, 2005 10:30 pm
Here's a few of the old truck with the buckets installed and rims and tonneau cover on....
PostPosted: Mon Aug 29, 2005 10:48 pm
hey hey nice truck
what seats are those from they look pretty good in there
your truck has the same big ass side mirrors mine have, fold them in and youll get better gas mileage..haha i wanna get some of those smaller ones from http://www.luvrestoration.com for like 34 bucks a pair
PostPosted: Mon Aug 29, 2005 11:02 pm
I got the seat for free from a guy here in town.. they are supposed to be from a mid 80's Astro Van...i'd like some sportier mirrors myself but the great big holes from these mirrors will be hard to fill
thanks for the comments
PostPosted: Mon Aug 29, 2005 11:06 pm
yah do you know if those mirrors were a factory option or aftermarket part
PostPosted: Mon Aug 29, 2005 11:08 pm
and also is your truck lowered at all or stock
PostPosted: Tue Aug 30, 2005 7:50 am
An old timer body shop trick to fill big holes is to leave the bolt in but not tight. Leave it loose enough to weld around the threads where it meets the surface of whatever its going through. Then just use a cut off tool to whack the eccess off and grind it smooth. Or if you dont have a welder you can dimple the hole with the round end of a ball peen hammer and use fiber glass fabric/resin and body filler. Used both methods on my Luv.
PostPosted: Tue Aug 30, 2005 7:53 am
Nice truck by the way. I dont think Ive seen it before. Those are astro van seats alright. Ive seen enough of them to know.
PostPosted: Tue Aug 30, 2005 8:21 am
Looking goood RB
Richard
PostPosted: Tue Aug 30, 2005 10:29 am
thanks everyone...
the mirrors are not stock but were on it when i got it...
the truck hasn't been lowered. it sits on some 15" rims with 50 series tires and that's it for suspension mods..
as for the holes int the doors, a trick i learned from aircraft work is to dimple the hole it and squeeze up a steel countersunk rivit in the hole... usually works good and is permanent...
PostPosted: Tue Aug 30, 2005 12:37 pm
Banishment Pending
nice looking Luv!!! where did you get the tonnue cover at? i'v been looking for one but I can't find them anywhere.
PostPosted: Tue Aug 30, 2005 2:54 pm
the tonneau cover is for an s-10 and it is a bit small. it's about 1 1/2 too narrow and and 1 or so too short.. but it will work for now.
PostPosted: Wed Aug 31, 2005 8:32 pm
hey bob i have smaller mirrors on mine and those holes are easy to fill i think it took me like 10-15 min. per door. i used fiberglass with fiberglass resin. if i knew how to put pics on here i would so you
PostPosted: Fri Sep 02, 2005 10:19 pm
i just noticed that they are the same mirrors that are on my 83 pup, i like them cuz they are BIG
PostPosted: Fri Sep 02, 2005 10:37 pm
yeah they look ok and give good visibility.. wouldn't mind something sportier though
PostPosted: Fri Sep 02, 2005 11:04 pm
lookin good... i like the wheels and the seats look good as well
i like the style of your door panels..
PostPosted: Fri Sep 02, 2005 11:15 pm
those are factory base model saddle color door panels... getting those replaced when i can.. gotta cover those giant holes in the door.. :wink:
and thanks..
PostPosted: Sat Sep 03, 2005 11:40 pm
Swap Specialist Mod
thats a good lookin truck you gots there man. what are you runnin under the hood. i dont know, but something makes me think your runnin a buick v6 :smt119
PostPosted: Sat Sep 03, 2005 11:46 pm
right now i'm running the stock 1.8 bottom end with some slightly different head. It looks like a 1.8 head but has a hole and boss for a mechanical fuel pump???
but for now it's a stocker.
PostPosted: Sun Sep 04, 2005 10:09 pm
nice truck clean
If you cant find it grind it
79 4x4 1.8 liter
69 Jeepster comando v6
PostPosted: Sun Sep 04, 2005 10:16 pm
thanks.. just go my junk truck dash pad in yesterday.. slowly coming together...
here's a before and after of the dash...
