It is currently Mon Jun 15, 2026 2:51 am
PostPosted: Sun Jul 03, 2005 5:18 pm
Luvtruck.com Wookie
scored this cause the winner didn't pay......
:see below:
gonna route it torwards the front and try to design a ram for the end of it. i've been smelling rich exaust when it's hot out so i figure this might help.
that and silencing that loud sucking noise under my hood.
TiLtEd wrote:
Boobies!!! :D
Last edited by where's all the luv at? on Sat Jul 30, 2005 11:30 pm, edited 2 times in total.
PostPosted: Fri Jul 29, 2005 6:38 am
Luvtruck.com Wookie
got the parts a few days ago......installed em, damn this thing flows a lot better than the stock air cleaner that came w/ the weber. a bit quieter untill i open up the secondaries....tyhen it's waaaaay louder.
TiLtEd wrote:
Boobies!!! :D
PostPosted: Fri Jul 29, 2005 12:24 pm
do the techs notice that your carb isn't stock when you smog it?
Dr. Frankenstein
PostPosted: Fri Jul 29, 2005 6:25 pm
Luvtruck.com Wookie
i live in a rural county and we only smog if there's an owner change....unless it's in the family....i've owned around 15 cars and i've only had to smog one of em.....
on the other hand i developed a problem.......i'm pushing too much air through the carb now and i need to custom set my float....
i get up to 6000 rpm in third and the engine cuts out and in and out and in....etc.....i've already checked my fuel delivery and the flow and pressure are good....what do i change? and how do i change it?
i belive i need to set the float to 42 mm (stock) if i set the float to a lower height will it stop draining the bowl? do i have to adjust the drop too?
TiLtEd wrote:
Boobies!!! :D
PostPosted: Sat Jul 30, 2005 1:37 am
damn!I have to smog mine at a "test only"smog place...every year!I'm clueless about your carb issues,sorry(that setup looks tight tho)
Dr. Frankenstein
PostPosted: Sat Jul 30, 2005 11:39 pm
i just have an open element air cleaner on mine. Was yours the same way?
PostPosted: Sun Jul 31, 2005 10:11 am
Luvtruck.com Wookie
mine came with the standard open element..... after i put this cold air pipe and ram filter on, it just started acting like the float is off. i had it do this once before and the float level was the problem, but it's set correctly now and still draining the bowl.
TiLtEd wrote:
Boobies!!! :D
PostPosted: Mon Aug 01, 2005 8:58 pm
Nice looking piece :thumbs up:
Yeah smog definitely sucks.... But here in Rhode Island, if the vehicle is over 25 years old, they wont even bother sticking it on the sniffer..
But there are ways around such... Such as a friend inspector that will put his unaltered on there for ya.... :wink: but you know... I would never condone any illegal activity :wink:
