It is currently Sat Jun 13, 2026 3:56 pm
Post new topic Reply to topic  [ 57 posts ]  Go to page Previous  1, 2, 3
PostPosted: Wed Mar 23, 2005 1:01 am
Took a better pic of the bed. I got the rest of it down at the top after this was taken...
Before I started tearing into the side...
This probably looks really funny, but I did it on the other side and it worked well to tell me where the high/ low spots were. I Used a wide flathead that has a sharp point and a hammer and worked diagnal downward chipping the filler away to find the fossils underneath...
A couple of the bigger pieces I pulled off the bedside...
Showing the areas that came off really easy...
Yum...
Most of the bed down. It will be finished next time I work on it...
I decided to go with a wire wheel instead of a sanding disk on this side. It takes about the same amount of time to get it down and I dont have to come back and smooth it out afterwards...
The filler for the blinker on the back corner of the bed...
PostPosted: Wed Mar 23, 2005 9:14 pm
Swap Specialist Mod
man, the work that was done to that thing looks like work that pee_roy does. he did his gas door like yours. but he didnt even weld it. just put a piece of metal in the hole and slathered on the bondo. it cracked the next day. he did the same thing with the hood too. pop rivets and TONS of bondo.
neil
PostPosted: Thu Mar 24, 2005 1:47 am
Some pople just don't know what they are doing.
Tearing out peoples crap they did takes twice as long. But I'm getting there. The truck is a little over halfway down. I have to get the rest of the passenger side done, the inside of the bed, and the rest of the inside of the cab.
PostPosted: Thu Mar 24, 2005 6:19 am
you should save all the bondo and see what it weighs....
I bet that truck is 500#s lighter when you get finished.
03Cobra
PostPosted: Fri Mar 25, 2005 3:45 pm
8O 8O 8O 8O I'm speechless everytime I look at those pics
hahaha thats funny, really makes you wonder how much is there,
you should post these up on SSM too so everybody there can see this shit
PostPosted: Sat Mar 26, 2005 8:53 pm
I posted a few, but I hate the message board. Too many people with bad attitudes, so I stick to the member profiles and mag.
 Post subject: ressurection
PostPosted: Sat Apr 02, 2005 2:04 pm
Damn! Your ride makes me feel alot better about the condition of my truck,your doing us all agreat service. Im looking forward to the pics of the finished product. did those front bags mount to stock control arms?
Dr. Frankenstein
PostPosted: Sun Apr 03, 2005 10:42 pm
Time for an update FINALLY!!!
The dust pile from the passenger door, a little strip on the bed, some of the cab behind the door, and some of the fender...
Bed is done minus the small area above the body line...
Showing the door and fender...
Put one of the spare 275/35/18 tires next to the bed to show how much room I don't have...
Showing that the back of the cab lays...
And the front does not. Until I raise the transmission crossmember...
Side shot. You can see some of the lumps and bumps in the metal...
 Post subject: Re: ressurection
PostPosted: Sun Apr 03, 2005 10:43 pm
Yes the bags mounted to the factory control arms. I'll most likely be building some sometime in the future when I go with larger wheels. I'll get to the suspension breakdown in a month or so.
PostPosted: Thu May 26, 2005 1:17 am
Swap Specialist Mod
i saw the further work that youve done on dfwminis.com. its looks better and better every time ive seen it.
are you gonna use the 2.8 you hae to power it? i was just gonna say that it would be truck with a 4.3 or somethin.
mkay
neil
PostPosted: Tue May 31, 2005 4:09 pm
Right now it is sitting until I get my blazer sold and do a few more things to my car to make it easier to drive daily.
I'm not sure what motor I'm going to go with, that part is pretty far down the road. I'm going to do alot more to the truck then I planned at first, so it will be easier to do all of it without the motor.
PostPosted: Tue May 31, 2005 4:15 pm
Swap Specialist Mod
is that mercedes yours? the black one thats bagged? but yeah i understand. sill a ways to go before that things done.
neil
PostPosted: Tue Jun 07, 2005 8:11 pm
please email me,the owner of this truck.i would like some info on the truck.how its body dropped and bagged.if you can give me some good detail it might be worth some $.email me @ lvngfam3@yahoo.com
PostPosted: Mon Jun 20, 2005 12:29 am
neil
Yes that is my mercedes, and the reason the luv has not been worked on lately. :lol:
PostPosted: Mon Jun 20, 2005 12:31 am
It is all being redone. I could show you pictures and tell you how not to do it, and give you a few poiunters on what would work better. I plan on changing everything that was done and a whole lot more on this truck. I'm on AIM alot it would be easier to talk on there...
AIM S/N- T Baggin S10
PostPosted: Mon Aug 01, 2005 6:55 pm
My god! Does that guy have a parts store or did he get all that bondo at a yard sale? It would have been interesting to weigh the truck before you started and after your finished.
PostPosted: Tue Aug 16, 2005 5:40 pm
I have filled up my huge trash can too many times to count with junk out of this piece of crap. I'm finally going to get back to work on it pretty soon. I have been working on the car and alot of other peoples rides lately so I have had no time for the truck. I'll post some pics soon hopefully.
