It is currently Mon May 25, 2026 11:46 am
PostPosted: Wed May 11, 2005 3:39 pm
Well Currie sent me back a e-mail asking for the pinion offset. So i was wondernig for those of you that have tubbed your luv what pinion offset you used. It appears to be center offset but i just wanna make sure.
PostPosted: Wed May 11, 2005 9:45 pm
YOU NEED TO HAVE THE PINION IN THE CENTER OF THE TRUCK. ONCE YOU HAVE IT CENTERED YOU CAN MEASURE FROM THE PINION THE HOUSING ENDS. THEY SHOULD BE THE SAME, ALTHOUGH THE AXLES WILL NOT BE THE SAME LENGTH., BECAUSE THE PINION IS NOT IN THE CENTER OF THE HOUSING. CONFUSED YET? GO TO MOSSER WEB SITE AND LOOK AT THE DIAGRAM ON HOW TO MEASURE..ARE YOU CUTTING YOUR OWN HOUSING ? AND WELDING NEW ENDS OR WHAT??
PostPosted: Thu May 12, 2005 1:35 pm
No, Currie enterprise is building the rearend, they just need to know what pinion offset it is. I'm also having them install the 4-link brackets.
