It is currently Wed Jun 17, 2026 2:36 am
 Post subject: ugh! engine prices!
PostPosted: Mon May 09, 2005 3:16 pm
I just got an email for a price on a used toyota engine...895.00!!! WTF! I thought I was looking for a cheap alternative, well I printed the pages on the hooker install and the v-6 mounts this seems like the second most popular swap can someone tell me the difference btwn the chevy and the buick? seems like the buick gets all the v-6 use. There must be a reason that I dont know,and it seems like its gonna be as expensive as any other upgrade. Someone give me some direction please!
Dr. Frankenstein
PostPosted: Mon May 09, 2005 9:04 pm
LUVTruck.com's Cornholio
Are you puttin this in a Toyota pickup? If so I think that the Buick's stock engine mounts bolt right to the trucks stock motor mounts.
PostPosted: Mon May 09, 2005 9:44 pm
well I gots a 78 long bed luv looks a lot less done than yours. I wasnt thinking tear up the streets motor but this stock 1.8 seems anemic lookin at some of these toyota parts made me think it'd be easy to put in the toy... and gas is like three dollars a gallon here in 'frisco. But maybe not the right choice . The engine I've got runs real well, the g200 w\ the g180 heads is do-able isnt it? But thats short term, does the Buick 4.1 have some advantage over the chevy 4.3?
Dr. Frankenstein
PostPosted: Mon May 09, 2005 11:45 pm
buy a 22r toyota motor with a 5 speed and ull be more than happy ive had a 20r and a 22r in my 75 luv and it was fast and good on gas as far as mounts and stuff u have to make them its not hard to do.
PostPosted: Tue May 10, 2005 1:12 am
Swap Specialist Mod
just curious, but do you have to weld a toyota yolk on the luv driveline, or does it just work?
neil
PostPosted: Tue May 10, 2005 1:30 am
thanks , Should I look for a donor toyota and gank some of the mounts out of that or is it like adapter plates? did you get a used engine and rebuild it or a used import? those engine whorehouses seem like highway robbers. Did you get a custom driveshaft? (your truck looks tight FJ) I was thinking what Farmerjoe asked as well
Dr. Frankenstein
PostPosted: Tue May 10, 2005 11:11 pm
when i got my 75 it came with a 20r so the drive shaft and evrything was all done but i cant tell if it was made or welded on but mostlikely u have to weld the yolk to the drive shaft as far as motor mounts yeah u just align the motor in the truck make some brakets and stuff. as for the trans all u have to do is drill 2 or 4 lil holes depending on what trans ur getting. i got my 22r motor for 300 bucks from a salvage yard. and the trans i used the 20r trans. most 22r and 20r parts are interchangeable. and for cooling, stock rad does fine if u take ur time and align the motor good and u can be able to use the stock toyota fan and fan clutch
 Post subject: 22r
PostPosted: Thu May 12, 2005 10:24 am
thanks man how was the mileage on that combo?
Dr. Frankenstein
 Post subject: Gas Mileage
PostPosted: Thu May 12, 2005 5:52 pm
My truck is not done yet, but a friend of mine with a 305, and a 700r4 gets 24 miles to the gallon.
PostPosted: Thu May 12, 2005 8:56 pm
i was getting like a cool 28mpg with 4.56 gears i think if u get a rear out of a auto luv with 4.10 u will be cool
PostPosted: Fri May 13, 2005 12:22 am
The 4.10 is way up on the wish along with a 5speed, it is sort of cool being able to break traction at will tho. but jeez its like having a 3speed.
Dr. Frankenstein
