It is currently Mon Jun 08, 2026 8:03 am
 Post subject: Got a new luv
PostPosted: Sat Apr 16, 2005 9:59 pm
I just came across a new luv 79 4wd, Its got a problem with it, it was running when i got it but it cough through the carb and would not exceede 40 mph , it has great compression new plugs and wires, Ran the truck up on #1 tdc and the rotor is on #4 and when #4 is on tdc the rotor is on #1 it is the oppsite of what it should be any help would be great
 Post subject: tdc
PostPosted: Sun Apr 17, 2005 12:09 am
You're going to get #1 TDC on compression but also on exhaust. Pull the valve cover, and when #1 intake and exhaust valves are closed defines compression.
 Post subject: #1 tdc
PostPosted: Sun Apr 17, 2005 1:46 am
I had already backed off all te valves becase when i went to adjust then and then when #1 was set brought it around to 4 and 1 was loose again I dont know know where to go from here
 Post subject: valves
PostPosted: Mon Apr 18, 2005 3:59 pm
I'll email you 2 pages out of my manual about setting valves.
PostPosted: Fri May 06, 2005 12:48 am
mine did that too. just walk the wires around. switch 1 and 4 then 2 and 3, see if that works
