It is currently Mon Jun 08, 2026 12:57 am
PostPosted: Fri Apr 08, 2005 11:05 pm
My wipers are only going at the slow speed. I replaced the plastic things
that mount under the dash. with a metal set up. The shaft is also packed with Marine grease. So I am thinking either my switch has a problem,
or the motor might be going out.
Any suggetions?
PostPosted: Sat Apr 09, 2005 9:44 pm
Those motors only had 2 speeds... slow and really slow.
PostPosted: Sat Apr 09, 2005 9:54 pm
http://www.rainx.com/
i swear by the stuff :wink:
seriously if they are only working at one speed tho...id look at the switch first.
PostPosted: Sun Apr 10, 2005 11:13 pm
Switch has got my vote as well...
Resident lurker
PostPosted: Mon Apr 11, 2005 5:28 am
getting good voltage to the motor could be helpful also.
if you have stock wiring, and running other things ie. lights, heater, etc.... it may not be getting good voltage to the motor.
Have you noticed that it speeds up or slows down as you turn on more lights, or the heater?
03Cobra
Users browsing this forum: Google [Bot] and 27 guests
