It is currently Tue May 26, 2026 1:03 am
PostPosted: Tue Jan 11, 2005 5:51 pm
This was done by graphicdisorder.com, cool site, check it out!
click on an image for a larger picture.
Tyler, TX
BAGGED '79 LONGBED
PostPosted: Tue Jan 11, 2005 7:13 pm
Very sweet
I like the buick style fender vents :D
Cement Shoes available here....One size fits all!
"Rum And Pepsi's Got Your Whole Perception Of Me Sketchy.....Cause When I Stage Dive, People Are Scared To Catch Me"
PostPosted: Thu Jan 27, 2005 6:34 am
sweet, another mini trucker... your truck is gonna be bad ass when its finished, its probably bad ass right now, (i havent seen a current pic) what set up did you use on the ass end of yours? is the suspsension similar to an s-10? im going to pick up my luv today hopefully, get it runnin and shave it, probly gonna drop it with bars and blocks until i get done bgging my s-10, then i will cut the b*tch up... i dont know how to insert a picture into this post, so here is a link to a whole bunch of picshttp://photobucket.com/albums/v507/Iroc_S10_87/, there is a photoshop of about what i want my luv to turn out like... later
PostPosted: Thu Jan 27, 2005 6:31 pm
it has a torsion bar setup in the front, back is just like anything else.
Tyler, TX
BAGGED '79 LONGBED
PostPosted: Thu Jan 27, 2005 6:32 pm
i built a 2-link for the rear
Tyler, TX
BAGGED '79 LONGBED
PostPosted: Fri Jan 28, 2005 12:54 am
cool, do you think i could modify an s-10 4 link to work on the luv, i wanna hit sides with it, if it goes how i plan i want some of those 3/4" or 1" valves off of a big truck with a nitrogen bottle, maybe i can do side to side and roll it over... it'll be like airdraulics, lol
PostPosted: Tue Feb 22, 2005 11:54 pm
all you need to do is hit up suicidedoors.com and get a universal triangulated 4 link
PostPosted: Wed Feb 23, 2005 3:08 am
Swap Specialist Mod
hey greenchevy, can drag with that thing. it would sweet to see some drag pics at like 40mph.
i also have another question. when you have the back set all the way down it the back with you 2 link how bad is the pinion angle. seeing how you did you rear setup makes me wanna do mine that way too.
PostPosted: Sat Feb 26, 2005 2:51 pm
i have pinion angle shims, and soon to be five inch blocks, so the angle is not that bad at all. i will try to get some drag pics soon, but right now the truck is apart and i am doing the body work.
Tyler, TX
BAGGED '79 LONGBED
PostPosted: Sun Feb 27, 2005 3:30 am
Swap Specialist Mod
ok. pinion shims. mkay ill have to remember when im doing my setup to get a coulpe of them.
neil
PostPosted: Tue Mar 01, 2005 11:08 pm
why not just do a proper 4 link that way there are no issues with the pinion angles at all? The cost diff makes it almost not worth messing with the 2 link. Jason at suicidedoors.com is where I had my 4 link for my truck made, $199. Its a trianguled setup so it doesn't hit sides, which is cool with me but you could get the bars made with heim joints and that should take care of it
I TOOK UR MOM DRAGGIN LAST NIGHT
Bagged 84 Pup
Bagged 53 F100
stock 72 Citroen DS19
PostPosted: Sat Mar 05, 2005 2:17 pm
built the 2-link myself, very cheap, did not want to relocate gas tank
Tyler, TX
BAGGED '79 LONGBED
Users browsing this forum: Google [Bot] and 29 guests
