It is currently Sun Dec 21, 2025 3:14 pm
PostPosted: Tue Jan 11, 2005 5:51 pm
This was done by graphicdisorder.com, cool site, check it out!
click on an image for a larger picture.
Tyler, TX
BAGGED '79 LONGBED
PostPosted: Tue Jan 11, 2005 7:13 pm
Very sweet
I like the buick style fender vents :D
Cement Shoes available here....One size fits all!
"Rum And Pepsi's Got Your Whole Perception Of Me Sketchy.....Cause When I Stage Dive, People Are Scared To Catch Me"
PostPosted: Thu Jan 27, 2005 6:34 am
sweet, another mini trucker... your truck is gonna be bad ass when its finished, its probably bad ass right now, (i havent seen a current pic) what set up did you use on the ass end of yours? is the suspsension similar to an s-10? im going to pick up my luv today hopefully, get it runnin and shave it, probly gonna drop it with bars and blocks until i get done bgging my s-10, then i will cut the b*tch up... i dont know how to insert a picture into this post, so here is a link to a whole bunch of picshttp://photobucket.com/albums/v507/Iroc_S10_87/, there is a photoshop of about what i want my luv to turn out like... later
PostPosted: Thu Jan 27, 2005 6:31 pm
it has a torsion bar setup in the front, back is just like anything else.
Tyler, TX
BAGGED '79 LONGBED
PostPosted: Thu Jan 27, 2005 6:32 pm
i built a 2-link for the rear
Tyler, TX
BAGGED '79 LONGBED
PostPosted: Fri Jan 28, 2005 12:54 am
cool, do you think i could modify an s-10 4 link to work on the luv, i wanna hit sides with it, if it goes how i plan i want some of those 3/4" or 1" valves off of a big truck with a nitrogen bottle, maybe i can do side to side and roll it over... it'll be like airdraulics, lol
PostPosted: Tue Feb 22, 2005 11:54 pm
all you need to do is hit up suicidedoors.com and get a universal triangulated 4 link
PostPosted: Wed Feb 23, 2005 3:08 am
Swap Specialist Mod
hey greenchevy, can drag with that thing. it would sweet to see some drag pics at like 40mph.
i also have another question. when you have the back set all the way down it the back with you 2 link how bad is the pinion angle. seeing how you did you rear setup makes me wanna do mine that way too.
PostPosted: Sat Feb 26, 2005 2:51 pm
i have pinion angle shims, and soon to be five inch blocks, so the angle is not that bad at all. i will try to get some drag pics soon, but right now the truck is apart and i am doing the body work.
Tyler, TX
BAGGED '79 LONGBED
PostPosted: Sun Feb 27, 2005 3:30 am
Swap Specialist Mod
ok. pinion shims. mkay ill have to remember when im doing my setup to get a coulpe of them.
neil
PostPosted: Tue Mar 01, 2005 11:08 pm
why not just do a proper 4 link that way there are no issues with the pinion angles at all? The cost diff makes it almost not worth messing with the 2 link. Jason at suicidedoors.com is where I had my 4 link for my truck made, $199. Its a trianguled setup so it doesn't hit sides, which is cool with me but you could get the bars made with heim joints and that should take care of it
Bagged 84 Pup
Bagged 53 F100
stock 72 Citroen DS19
PostPosted: Sat Mar 05, 2005 2:17 pm
built the 2-link myself, very cheap, did not want to relocate gas tank
Tyler, TX
BAGGED '79 LONGBED
