It is currently Mon Jun 08, 2026 5:54 am
 Post subject: valve adjustment ?
PostPosted: Tue Jan 25, 2005 7:49 pm
i was tinkering around with stuff i wanted to get my truck running better last night and i was trying to adjust the valves and the haynes book says
#1 TDC you can set
cyl 1 int/exh
cyl 2 int
cyl exh
#4 TDC you can set the rest
and the book says for clearance .006 intake / .010 exhaust
so i did that
with the #1 at tdc and then jumped over to the next step getting
#4 tdc and when i turned the crank to that all the valves i had just adjusted were totally loose at those settings ?
i lined up the mark on the cam with the one on the head for tdc on #1 piston
so i dont know why they were so loose
any help would be great
thanks
 Post subject: Valves
PostPosted: Tue Jan 25, 2005 8:09 pm
Did you pull the distributor cap and make sure the rotor was pointing at #1 spark plug wire?
PostPosted: Tue Jan 25, 2005 8:15 pm
no i totally spaced that :oops:
i wonder if my distributor is 180 it usually backfires when being shut off too
hmm i guess i ll have to find out
i ll do that robert thanks i appreciate it
PostPosted: Wed Jan 26, 2005 12:24 am
sure enough its 180 out on the distributor i checked the mark on the cam and the rotor was pointing on tdc on #4
then i adjusted them once again sure enough runs better
so that helped robert
so i got to pull the distributor this friday or so and get a power valve suggested from one of the fellow luv members from blowing it out when
backfired through carb
