It is currently Sun Dec 14, 2025 12:47 am
 Post subject: Rebuilding the 4
PostPosted: Sat Jan 08, 2005 3:28 pm
i have a 80 luv with the original 4 in there, only the guys who owned it before tore the whole engine apart. we put it back together so it will start up and run (like sh!t) but all the emmisions are just layin there. so my question is are those emmision necessary for the truck to run good? im not worried about smog or anything, just want the original 4 to run like a champ. if someone know a site or has removed emmisions from their luv please let me know how you did it. thanks
-max
PostPosted: Sat Jan 08, 2005 4:23 pm
The EGR valve is one bit that can help the motor run better while reducing emissions. It keeps cylinder temps down, which keeps the motor from having detonation or pinging. This means you can buy lower octane fuel without worries and you can advance the spark a little bit and gain a little power. The EGR valve is at the end of the metal tube that connects the exhaust manifold to the intake. It takes a vacuum line that runs from it, to a little two port valve on the front edge of the intake, then that goes to the carb.
The other stuff, well it all does something to reduce emissions. Most of it has very little effect on performance directly one way or the other. It can have a big effect though if just left off without capping vacuum ports or whatnot. One open vac port will really make a truck run like crap.
PostPosted: Sat Jan 08, 2005 6:09 pm
do you have any picture of all the emmisions hooked up? id really appreciate it, cause all the hoses are just sitting there, duno where all of them go
PostPosted: Sat Jan 08, 2005 11:03 pm
I live in colorado and have to get emissions on my LUV . I got this truck in North Dakota so it didn't have any of the emissions stuff on it. The picture that helped me the most was on bcg187's web page. It shows the smog pump as well as the vacumum actuated valve that goes with it as well as the hose routing. Thanks for that great pic. bcg187. Hope this helps
http://www.cardomain.com/member_pages/v ... _id=418724
PostPosted: Sat Jan 08, 2005 11:14 pm
how did you do it without the emmisions? this truck is going to idaho and dont need it. id rather have it out but if i could get it to work thats fine. so if someone could show me what to remove/cap off please let me know.
PostPosted: Sat Jan 08, 2005 11:44 pm
LUVTruck.com's Cornholio
Are you going to end up moving to Idaho?
PostPosted: Sun Jan 09, 2005 12:04 am
no, im takin the luv to my uncle during spring break. then im commin home (cali)
PostPosted: Mon Jan 17, 2005 12:07 am
Is this 80 the Redish one that was just on e bay in San Clemente?
PostPosted: Thu Jan 20, 2005 7:17 pm
nah, not the one on ebay
anyways im looking for pictures of peoples 4 cylinder. mainly the carburator and emmisions. i need to know where all the hoses go. i have both Haynes and Chiltons manual and they dont have it. so if anyone has some pictures or infromation, please help
PostPosted: Thu Jan 20, 2005 7:47 pm
vroom,
i have the service manual for that year, and have a truck that year with california emmisions so let m eknow just what you need and i can probably help you out.
PostPosted: Thu Jan 20, 2005 7:55 pm
pictures of all the emmisions, and detailed pictures of the hoses on the carb and where they go.
if you could. thanks so much.
PostPosted: Thu Jan 20, 2005 8:06 pm
check yer pm's
