It is currently Sun Dec 21, 2025 8:04 am
PostPosted: Sat Jan 08, 2005 1:54 pm
have the chance to buy a s10 with a v8, etc.....i also have two luv part trucks out in the driveway .....has anyone tried to put a luv body on an s10 rolling chassis? just curious....any responses would be helpful
PostPosted: Sat Jan 08, 2005 4:08 pm
I don't think I've heard of anyone doing that swap. In general there isn't really a good reason to do it that I can think of, unless chassis parts are easier to find for the S10. The LUV frame is stronger than most full size trucks. Other than a situation like you are looking at (substantially upgraded/modded S10 frame), I can't see too many people going through the trouble of swapping bodies when it is about as easy to move motor and all that into the LUV.
PostPosted: Sat Jan 08, 2005 11:02 pm
I would say its worth trying if you have the ability. S-10 bolt on chassis parts are endless. From front/rear bag kits to fully prepped race type rears. Wheel selection would also be huge. You would be dealing with a newer chassis so stock replacement parts are at every parts store, if you keep it stock.
PostPosted: Sun Jan 09, 2005 1:20 am
The more I thought about this one the more I realized that it would open up a lot of doors for replacement and aftermarket parts. Technically speaking I'd say the LUV frame is stronger and a better platform to build on. However, reality is that you can buy a hundred times more off the shelf parts for an S10.
I guess I can't be too negative on the idea. For a long time I did want to drop a LUV body onto a GMC Cyclone chassis. ;)
PostPosted: Sun Jan 09, 2005 10:18 pm
I think theres someone here by the name of "jstorm" who's done this swap. I know over on a trditional hot rod message board we both hang out at that he said he'd swapped over to the S10 chassis. Search the members list & PM him.
'46 Studebaker truck "project"
'90 Trooper 4X4, 2.6L 5 spd
PostPosted: Sun Jan 09, 2005 10:26 pm
Heres a link to his profile here-
http://forums.luvtruck.com/profile.php? ... file&u=811
Only 2 posts by him, but maybe he'll respond to a PM.
 Post subject: thanks for the thoughts
PostPosted: Mon Jan 10, 2005 7:16 pm
i have one luv with a 350 and standard hotrod additions, and the 10yo thinks that it is hers....the s10 has a 350 instead of v6.....and i have 1.5 luvs in the front driveway.....though i could try a switcheroo with the daughter so i had the real hotrod and she had the real version to drive to school when the time comes....now the wife wants a mini.....i always heard luv frame is VERY srong but as ya'll guessed other updates are more readilly available for anything but a luv suspension...i'll just see how inexpensive i can get the s10 and go from there
