It is currently Tue May 26, 2026 1:37 am
PostPosted: Wed Nov 10, 2004 12:18 pm
The 383 and 200-4R are in the Luv, and I've made a trip to the drag strip.
383
10.8:1
TFS 215R heads - home ported - 301/236cfm
Comp 224/224 hyd. roller, 114LS, installed 110CL. (smooth idle)
RPM intake
HP950
74 Luv (3000+/-lbs w/driver)
200-4R
12" 2000 stall
307gears Dana44
Here's the bad part, its got 1 5/8" block huggers, full length headers would be nice.
From there I built a 3" X-pipe to 2 1/2" dynomax turbos with 2 1/2" tail pipes.
The cool thing is the 383 still sounds like a work truck with the turbo
mufflers, since it idles smooth/quiet!
Best pass was 11.66 @ 116.2
It’s a dog off the line with the 2000 stall & 307 gears, and in 3rd gear its not really
in the power band, as it crosses the line at 4800-4900rpm. I'm gonna put the lock up
switch on the 200-4R for the converter, and hope it picks up a bit. Plus the cool
weather is here now, so that should be worth something.
74 Luv - 383, 224/224cam, 200-4R, Dana 44 w/373s,
smooth idle "work truck" - 11.30 @ 121.8
67 camaro - 502 street/strip (inthe10s)
PostPosted: Wed Nov 10, 2004 12:21 pm
Japanese Redneck
thats a good ET for what you have in it. pretty impressive.
1978 LUV Truck 2WD
450 "Small Block" Chevy
3.70 Ford 9
28x10 Goodyears
PostPosted: Wed Nov 10, 2004 5:20 pm
Nice :)
PostPosted: Wed Nov 10, 2004 10:00 pm
Cool man! Sounds like fun!
Resident lurker
PostPosted: Thu Nov 11, 2004 2:01 am
COOL!
Lookin for another one.
PostPosted: Sat Nov 13, 2004 6:43 pm
Thats pretty quick, but if you're already droping below your RPM range why would you want the converter to lock up. That would bring the RPM down further and slow you down.
PostPosted: Mon Nov 15, 2004 4:12 pm
I'd hit the (manual) lock-up switch at around 5500rpm, so the engine would
pull better in (powerband) 2nd gear, shift at 6500rpm, which the lockup should
keep the 383 in 2nd gear longer, so I would be farther down the track before hittin
3rd gear. I've talked to a few guys using the lockups and they say you can pick
up 2-3mph, but with 307 gears it may not do much... we'll see.
PostPosted: Tue Nov 16, 2004 8:48 pm
AHH I C. :roll:
