It is currently Sun Jun 07, 2026 8:02 am
 Post subject: electronic ingnition
PostPosted: Thu Nov 14, 2002 4:34 am
I wonder if anyone knows if a Pertronix electronic ingnition will work in a 1980 luv 4X4. I noticed they only offer it for up to 1975 trucks. What is the diff. if any between the distibutors. Does anyone know of an alternate electronic system I could put on my truck?
1980 4X4 LUV
PostPosted: Tue Dec 03, 2002 5:19 pm
As far as I know, they make Ignitors for just about everything- I just ordered one for my '74- check out the Pertronix site. The guy I talked to didn't even seem to think I was weird for asking for LUV parts....
PostPosted: Mon Dec 30, 2002 6:55 am
Hey there, I installed a Crane Cams XR3000 electronic ignition in my 79 4x4. I believe its got a Nippon Denso. It took me a little bit to figure it out since I had never done a swap out before but man... worth EVERY single penny!!! The thing fired up on me first try after I left it sitting for 4 months. Not sure about Petronix although I hear good things. If you want to go with a great system, look into the XR3000.
 Post subject: Electronic Ignition
PostPosted: Wed Jan 01, 2003 4:56 pm
I found that Mallory makes a complete distributor for the Luv 1.8. It is under the name of Unilite distributors. Good luck.
 Post subject: Pertronix
PostPosted: Mon Aug 11, 2003 3:41 pm
Last time I checked, '79 was the last year. If you pull your distributor and send it to them, they'll make you a custom module.
 Post subject: Mallory
PostPosted: Wed Aug 13, 2003 7:40 pm
I put a Mallory Unilite in my 1980. Costs just over $300, but I like the way it works. And no damn points.
PostPosted: Wed Aug 13, 2003 8:04 pm
Here's the site and model for the Mallory Unilite I put in my 1980.
http://www.centuryperformance.com/detai ... AL-4765501
PostPosted: Thu Aug 14, 2003 6:09 am
350 :x
PostPosted: Fri Aug 15, 2003 2:11 am
i did the whole shabang whith new everything and just ran parts for an 81-81 luv. The results are awsome, more power better idle and better econimy. I dont know of all the changes from first to second gen. luvs but i know the third gen. luv igniton will go into a second gen easilly.
Users browsing this forum: Bing [Bot] and 20 guests
