It is currently Mon Jun 08, 2026 4:11 am
Post new topic Reply to topic  [ 27 posts ]  Go to page 1, 2  Next
PostPosted: Tue Nov 02, 2004 2:28 pm
Today is the coldest day we have had since I put new engine in my truck.
It's ran great all summer, but this morning when starting it,it ran for a min or 2 then quit, did this about ten times, hasn't made it out of it's on tracks yet.
Since then i have gone and got a can of "heet", then replaced the igniter, coil, points, cap, rotor, and all the wires.....now it doesn't even TRY to start, and bear in mind ....i am NOT a newbie w these trucks.
This thing is costing me because I can't get ANYthing done w/o it. I need some advise on what may the prob , or else it and everything else that even resembles a LUV is going to appear in the "classified" section of this forum, very soon.
I am fed up w undependable hunks of crap, thought i had a good truck, cause everything under the hood was just replaced like 6,000 miles back.
ANY input or advise would be greatly appreciated, or even a trade for all this LUV crap for one good dependable full size pickup.Tired of this crap,thinking my best bet is to sell it all and move on to something a lil more modern.
PS Those of you trying to get ahold of me today at my yard....i'm sorry I am not there, thanks to this POS in my driveway, if it's anything important , then please contact me here at home at 806-331-2208...thanks******Duane******
PostPosted: Tue Nov 02, 2004 2:48 pm
8O 8O Uh Oh!
This may be dumb but is it getting fuel? Fuel pump maybe? Stuck Carb floats?
Cement Shoes available here....One size fits all!
"Rum And Pepsi's Got Your Whole Perception Of Me Sketchy.....Cause When I Stage Dive, People Are Scared To Catch Me"
PostPosted: Tue Nov 02, 2004 2:50 pm
Just a few mins ago i poured fuel down it, to see if it was a fuel prob but it STILL won't start :(
PostPosted: Tue Nov 02, 2004 2:57 pm
Dang thats a tough one. :?: It has to be lacking either fuel or spark. Try testing for spark at the plug and fuel at the carb input. Has to be one or the other
PostPosted: Tue Nov 02, 2004 4:26 pm
I just got back w a fresh battery.it will crank at the key but no fire from key, so i hot wired from +side of coil to + side of battery, it fired right up, ran great.....for about min, then it shut back down,just like as if you would turn off the key 8O
Does anyone know if those lil sensors in the box on right side of cowl have anything to do w the ignition...i now know my prob lies somewhere in my ignition system, most definelty..any and all help is GREATLY appreciated.
otherwise it may not have a driver door glass pretty soon, i am getting awful mad at this truck right now :twisted:
PostPosted: Tue Nov 02, 2004 5:05 pm
There are two relays under the metal cover right behind the coil, one is for the fuel pump and the other is for the resistor bypass on the coil. The resistor bypass relay is the one with less wires to it. If it fires while you are cranking but then dies as soon as you let off on the key (to ON) then either the bypass resistor relay is bad or the resistor itself is bad. (or its wiring around the two, always a source of troubles) If you wire from the battery to the resistor on top of the coil and you can get it to run, you know the resistor is good. Something like this:
12v----resistor---+SideOfCoil
Then its either wiring, that bypass relay, or something that controls it.
If you had power straight to the coil from the battery and it ran, it should have kept going unless something else was wrong though. The coil should handle straight 12v for quite a long time before burning up, so I doubt direct wiring like that could fry it. My guess is that the fuel pump is also not kicking on. You get about a minute of idle before the carb bowl dries up. Both those relays drive off the voltage reg I think. If the reg or the alt went out on you, it could cause both the resistor relay and the fuel pump to cut out. You might be fighting both fuel and spark problems. Since they both have a bypass for starting up, its hard to troubleshoot when you can't get it to run/stay running. Cranking it over they would both seem to be working. If you have a known good reg and alt, I'd throw them on and see what happens. Crazy as it sounds, my gut says its a charging problem.
Actually, after looking at the wiring diagram until my head hurt, the resistor bypass relay powers the coil (through the resistor) and the fuel pump after the engine starts. If that relay goes, spark and fuel both go. Swap the relay or test it. If that doesn't get it, I'm thinking alt/reg problem. Also, just a sanity check for ya, make sure your fuses are good. There is one involved in all this (#5 from the front on 78+ trucks, dunno on the older ones)
PostPosted: Tue Nov 02, 2004 5:08 pm
Also, just something I was thinking about while looking at the wiring diagram: This is exactly why I have not converted over to a bigger, cheaper, simpler alternator through 4 LUVs over 15 years. The wiring needed to get gas and spark working right again makes my head hurt. ;)
PostPosted: Tue Nov 02, 2004 6:05 pm
Thank you VERY MUCH for all your input there 800xl..... :D
I am now changing the fuel filter, cause i think i got ahold of some crappy gas, I had it running via the hotwire for about 30 mins traight awhile ago.So once i change filter I will then check into those resistors.
Thanks again
PostPosted: Tue Nov 02, 2004 6:47 pm
That's it...I'm fed up this dam thing , so it is NOW for sale.
I have woreked all day in the cold cannot get it going, it lets me down right when I need it the very most, and I am going to lose out big time because of this.i cannot take anymore, i keep spending money buying parts to find out now that it wont even fire when I hot wire it straight from coil to battery.
I want this thing GONE ASAP, along w everything else I have that even resembles a chevy Luv, I'm considering any REASONABLE offer for ALL of it....this includes 3 trucks and helluva lotta parts.
PostPosted: Tue Nov 02, 2004 9:14 pm
Breath in through your nose, out through your mouth. Count to 10, have a beer, and try to relaxe. It has to be something reall simple. WHAT, I am not sure, but I have a feelin youll finger it out. I HOPE :D
PostPosted: Tue Nov 02, 2004 9:21 pm
Thanks man, for the encouraging words :D
Tilted basically told me the same thing, so i got away from it for the night, and plan to start all over in the morning.
If all esle fails, then i will just drop this engine in my new red 79 longbed, cause I have a hunch that it's in my wiring somewhere. :roll:
You guys are too cool, and lord I just wish I could be half as mellow as some of you guys :?
Thanks again, ALL responses have helped in some way or another 8)
PostPosted: Tue Nov 02, 2004 10:12 pm
Whew, I was afraid to say anything cause ya looked like you were about to pop.
1980 Luv Mikado 4X4
PostPosted: Tue Nov 02, 2004 11:41 pm
Lil Blue,
I with you man, I know it can be a Bitch (excuse me). We have all been there and done that. Some times we have to take a breath step back and hit again after a rest. It is easy to throw in the towel, many times I have held a 10 lb sledge hammer and considered..., well you understand. But this is what separates the true "wrench head" from the wanna be's. Cause in the end we will figure it out, fix it and feeling proud as we cruise in our ride. If it was easy everyone would be called "wrench head".
By the way I had the exact same problem on my '76 Luv many, many moons ago, 15 years to be exact. This was before I did a V6 swap. I think it turned out to be the #6 fuse. If you trace the schematic for the 76, fuse #6 connects to pin #4 on the resistor bypass Relay and the ballast resistor. Both of these circuits feeds the Positive side of the coil.
It took me 2 days to find this one and I was tempted to use the hammer. This may not be the same problem but I just wanted to say hang in there it will be worth it.
kaneguy
PostPosted: Wed Nov 03, 2004 12:05 am
Banishment Pending
Now Now Lil Blue just have one of these :drinking: and just chill, you can't get that upset in only 3 days! heck my truck's been down since July and STILL don't know what the frigin problem is!!!!!! Just take a break and get back to it in the morning! :wink:
PostPosted: Wed Nov 03, 2004 9:01 am
yep, me and rez are in the same boat there for sure. You just can't give up on it.
1980 Luv Mikado 4X4
PostPosted: Wed Nov 03, 2004 9:52 am
Okay, now after a good night's sleep......i am headed back out side to face the beast.
Hopefully I have good news within a few hours.
Everybody cross yer fingers for me. :D
PostPosted: Wed Nov 03, 2004 10:14 am
Yaaaaaaaay! It's running again, all it was , was a dam fuse, those of you who told me about the fuses i Owe you guys a BIG Texas size THANK YOU!!!!! :D 8)
That's all it was 8O
I would have NEVER thought to even check fuses, never hadn't blown one in 2 years I've owned this truck 8O ....Well I guess I'm off to work here shortly, thanks again guys.....thank EVERYbody for listening and helping w my porb.
I'll be at the yard shortly, anybody needs me call the number below , bye yall
I reckon now i have more good spare parts thatn i thought , after all i changed on it yesterday LMAO :lol:
PostPosted: Wed Nov 03, 2004 10:49 am
Sweet! Glad to hear all is well again :D
PostPosted: Wed Nov 03, 2004 10:56 am
Great news,
Yep, that problem was a doozy. Glad to hear you're on the road again.
Your are a true "Wrench Head"
Kaneguy
PostPosted: Wed Nov 03, 2004 12:05 pm
See, now why can't I have that kinda luck? :P
1980 Luv Mikado 4X4
Users browsing this forum: Google [Bot] and 29 guests
