It is currently Tue May 26, 2026 8:39 am
 Post subject: Rotors?
PostPosted: Wed Oct 20, 2004 8:22 pm
I've heard a lot of talk about monza or vega rotor conversions and even read an article about it. But considering that they still have to be redrilled, what are the benefits of doing this upgrade? Are the stock Luv rotors inferior? Thanks
Jess
PostPosted: Thu Oct 21, 2004 5:11 am
no Jess I don't think there is anything wrong with the stock rotors.
the only reason to do the mod is for 5 lugs.
I had a spacer/adapter bolted to the stock rotors for years, but it makes the tires stick out of the wheel well.
anyone else have $0.02?
03Cobra
PostPosted: Thu Oct 21, 2004 5:54 am
I was thinking maybe availability of parts, but then I haven't had any problems finding anything so, lug pattern seems reasonable.... :?:
Resident lurker
PostPosted: Thu Oct 21, 2004 6:08 am
But didn't you still have to have them drilled and relugged?
PostPosted: Thu Oct 21, 2004 9:48 am
that is correct.
the vega rotors come with a 4 lug pattern.
03Cobra
PostPosted: Thu Oct 21, 2004 11:23 am
The only 6 lugs wheels readily available are too wide to properly fit under the front of a LUV. The stock rotors work fine. I bought re-drilled Vega rotors from LUV4ME-thanks, they work great.
PostPosted: Thu Oct 21, 2004 11:39 am
you are welcome.
hope they give you years of service!! :D
03Cobra
PostPosted: Fri Oct 22, 2004 10:01 pm
Ahh, got it now.. But if you had to have them redrilled, couldn't you just get the stock one's drilled? Or does the spacing make that impossible?
PostPosted: Mon Oct 25, 2004 5:12 am
I think the luv rotors are a 2 piece design and the way the hub is formed makes it difficult to drill.
I could be wrong, but if they were able to be drilled, the guy I had to drill mine in the first place wouldn't have put the spacers on.
03Cobra
PostPosted: Mon Oct 25, 2004 5:53 am
Alot of people consider wheel spacers/adapters to be unsafe for street use. I know people who have used them for a long time with no problems and others who have had them loosen up and shear lugs off the vehicle and even lose the wheel completely 8O . Could depend on the manufacturer but I wouldn't recommend using them :)
Cement Shoes available here....One size fits all!
"Rum And Pepsi's Got Your Whole Perception Of Me Sketchy.....Cause When I Stage Dive, People Are Scared To Catch Me"
PostPosted: Mon Oct 25, 2004 10:24 am
Japanese Redneck
spacers and adapters are also not legal at the drag strip.
1978 LUV Truck 2WD
450 "Small Block" Chevy
3.70 Ford 9
28x10 Goodyears
Users browsing this forum: Google [Bot] and 30 guests
