It is currently Sat Jun 13, 2026 11:44 am
Post new topic Reply to topic  [ 33 posts ]  Go to page Previous  1, 2
PostPosted: Sat Oct 09, 2004 8:47 pm
Not a bad looking truck for 250...
runs too, not bad at all...
Resident lurker
PostPosted: Sat Oct 09, 2004 9:05 pm
Not to shabby, looks like they have yanked all the smog off already, and you got a weber. Nice start!
PostPosted: Sun Oct 10, 2004 12:11 pm
ok i suppose if u flip the ball joints over crank torsions before doing so and then get the lowering blocks take a leaf out of each spring and it should sit low
i just want to lower it a lil bit 3 or 4 inches
i thought about bags but if somthin malfunctions then ur kinda stuck
took that ugly rear bumper off yesterday looks a whole bunch better
their is a rocker panel that needs repaired and their is just surface rust in bed and tailgate oh and left side the louvers i got to patch up make new ones
i knocked around on it didnt sound like anymore bondo on it
yah LUVINIT the weber and smog crap is plugged off they kinda cobbled somethings but runs good all except needs a clutch
let my friend learn to drive a stick in it yesterday damn near blew my good motor :evil: was tryin to shift into 3rd but put in first i quickly grabbed and put in neutral
just thought i d add that for laughs
PostPosted: Sun Oct 10, 2004 5:32 pm
Did ya clean off the forehead marks on the inside of the windshield yet??? :D
PostPosted: Sun Oct 10, 2004 7:57 pm
alright here is what i got done today
i was going to cut a chevy bow tie in it but im thinking of a led lighted one and french it in or somthing
 Post subject: Longbed
PostPosted: Tue Oct 12, 2004 9:33 am
Nice-a, a-very a-nice-a.
PostPosted: Tue Oct 12, 2004 10:49 pm
thanks
well i got the other door side done almost tonight
tomorrow will be done and so will the shaved marker lights hooks on bed
and maybe touch up pinholes in certain areas
order some lowering blocks and im gonna need those rocker panels that guy sells on ebay
its coming along though
i think i will be able to borrow a good sand blaster for the project maybe the next weekend get it to that point gonna work on it every night after work
PostPosted: Sun Oct 17, 2004 10:23 pm
update 10/17
well i got the hooks shaved the right side marker lights and antenna
spent about 3 hrs on this project
had to replace the rocker panel it must of had a half pound of bondo
so i made a new one the bends came out nice, trick is tack weld corners
and sides after every tack weld i take a wet rag and cool it which takes a
while but keeps from warping or holes in sheet metal
waiting to get solenoid kit for shaved handles
and this is my favorite thing i worked on today spent a couple hours on it
the hood is not finished yet jus a glimpse of it in process
im gonna make this truck somewhat resemble a shelby mustang front
nose you know the elanor kit off gone in 60 seconds i am gonna try to
make that kit out of metal so i dont have to spend a fortune
keep u updated though hope you enjoy the pics as much as i do cause i put in at least a good 20 hrs into it already :)
PostPosted: Mon Oct 18, 2004 5:59 am
Looks good, keep em coming!
Resident lurker
PostPosted: Mon Oct 18, 2004 6:10 am
LSX LUV Owner
lookin bad ass! howd u go about shaving the slots in the side of the cab?
PostPosted: Mon Oct 18, 2004 10:56 pm
im not the best at explaining but if their was like a draw function on this i could draw it out
well plasma cutter comes in hand with these situations i cut around from outside line to the door where there is like a 90 degree bend
then took a piece of scrap sheet metal measured out what i needed for it i think it was like 17" tall 9" bottom width and like 4 and 5/8" top width
i think that is figured with the 1" that bends around the door
and then i bent the 90 or whatever degree and left an 1 inch overlap for inside door like i said above
and of course once you do that you have to form it to the body so i cut lil slots in the 1 inch part that allows you to form the piece to the body to blend it in
but you need
sheet metal
sheet metal brake
plasma (recommend) or somthin to cut the piece out
and welder
grinder with (fatboy sanding discs) work real good
spray bottle with water to cool metal
primer or wd40 to keep from rusting
thats all i can think of right now
if worse comes to worse i can make an extra pair when i get a chance
hopefully tomorrow my hood will almost be done
phew long post
PostPosted: Mon Oct 18, 2004 10:57 pm
thanks for the compliments makes me want to do more
PostPosted: Tue Oct 19, 2004 12:42 am
definently keep it goin, and don't forget the pics :D
Users browsing this forum: Baidu [Spider] and 32 guests
