It is currently Mon May 25, 2026 6:44 am
Post new topic Reply to topic  [ 25 posts ]  Go to page Previous  1, 2
PostPosted: Thu Oct 07, 2004 8:45 pm
Luvtruck.com Wookie
my jet set showed up today.......if you get new jets don't expect a huge change in performance.
here's what was in my truck when i got the carb.
larger numbers are the secondary side:
air 160/170
idle 60/60
mains 140/140
here's what they sent me:
air 170/180
idle 55/55
mains 150/170
i had to block a port in the top of the carb also. solves the tilted/hard left over rich.
this is my impression of the changes... not much for power,i can notice a little sharper throttle and it doesn't feel like i'm over carburated as much...... i think that this carb is a little large still though........is there a smaler version of this carb around?
TiLtEd wrote:
Boobies!!! :D
PostPosted: Thu Oct 07, 2004 8:52 pm
Luvtruck.com Wookie
oops repost
TiLtEd wrote:
Boobies!!! :D
PostPosted: Fri Oct 08, 2004 7:54 am
I'm starting to think that the needle valve is too big and letting in too much gas for even the float to shut it down.
1980 Luv Mikado 4X4
PostPosted: Fri Oct 08, 2004 9:29 am
Luvtruck.com Wookie
i think i have the needle valve that came with my carb in a drawer some where it was good but i rebuilt the carb anyway when i got it. if i can find it i'll send it w/that ignition set.
do you want these jets ? or did you get those taken care of ? they seem a little lean for my truck and to tell the truth they ran alright around 6000-8000 ft going over the pass.
TiLtEd wrote:
Boobies!!! :D
PostPosted: Fri Oct 08, 2004 10:18 pm
All my jets are leaner than yours so I don't think that'll help, but I would love the needle valve. Unless you've got a pump jet lying around you could part with?. . .didn't think so.
Your moneys' already in the mail so it should be there Monday or Tuesday.
1980 Luv Mikado 4X4
Users browsing this forum: Bing [Bot] and 34 guests
