It is currently Sun Jun 07, 2026 6:57 pm
 Post subject: Tranmission fluid
PostPosted: Sun Jul 11, 2004 10:58 pm
Does the 1980 model luv require transmission fluid and if how so how do i put it in
PostPosted: Sun Jul 11, 2004 11:06 pm
Don't quote me on this but, I would think as with any vehicle, If it is a manual it probably needs 85-90 wt. gear oil and if its an automatic it would take dexron II auto trans fluid.
PostPosted: Mon Jul 12, 2004 12:14 am
ok thanks
PostPosted: Mon Jul 12, 2004 12:22 am
The manual tranny used in LUVs takes 30 weight motor oil, not 90W. 90 will probably not kill it immediately, but the trans is designed for something that flows better to get in and lube the bearings.
PostPosted: Mon Jul 12, 2004 9:46 am
it'll probably shift poorly if you use 85w90. the book i have shows 30w or 10w30 for hot weather!?!?
PostPosted: Mon Jul 12, 2004 10:58 am
Thank you all but now that i know what it uses where do i put it in at???
PostPosted: Mon Jul 12, 2004 12:55 pm
my dad ran 90w in it for 20years and mine is still going strong
I switched to 30w and my gas millage and cold weather driving is alot better. As far as filling it i dont know the capacity but theres a drain plug right twards the end of the tranny. The easiest way to fill it is to pull a shifter out and use a funnel to poure it down that hole.
PostPosted: Mon Jul 12, 2004 1:59 pm
thank you
