It is currently Mon May 25, 2026 10:55 am
 Post subject: rusty beds
PostPosted: Tue Jun 22, 2004 8:47 pm
The bed in my 75 luv is rusted and full of holes, anyone have any suggestion on waht to do. My body has some holes too and some advice on that would be great.
PostPosted: Tue Jun 22, 2004 9:24 pm
Cheap and easy or not so cheap and not so easy? Something that will last or something just to get you by?
 Post subject: Re: rusty beds
PostPosted: Tue Jun 22, 2004 10:23 pm
Shit can it, and find something in better shape :D Or get a liner.
PostPosted: Tue Jun 22, 2004 11:02 pm
I gots me a liner!! Bad idea. Water got under the liner...sat there for awhile until it dryed up. And it left some HUGE rust spots now. So the liner wasn't such a good buy for me..
Spray-In-Liner however..
PostPosted: Wed Jun 23, 2004 12:17 am
Well since his is already messed up, I don't see what a liner could hurt.
PostPosted: Wed Jun 23, 2004 12:56 am
New bed......
PostPosted: Wed Jun 23, 2004 5:22 pm
I want something that will last and look good no matter how hard. Cost is an issuse- Nothing outrageously expensive.
PostPosted: Wed Jun 23, 2004 9:01 pm
can you weld, grind, sand, and finish?
If everybody grows up with high self-esteem, who is going to dance in our strip clubs?
What's going to happen to our porno industry?
These women don't just grown on trees.
PostPosted: Thu Jun 24, 2004 9:09 am
You could either weld some patches in it or get some rust converter and fiber glass over it. Of cousre welding patches would be best, but if you dont have a welder or access to one, you would have to glass it. Are you able to post pics so we know what you are dealing with?
PostPosted: Fri Jun 25, 2004 2:54 pm
I have a few picture. None of them show the bed. I don't know how to post pictures so could tell me and i'll post what i have.
PostPosted: Tue Jun 29, 2004 9:00 pm
I need to know how to post the pics.
Do you know how to make the body shooth for paint when it has lots of small rust pits all over. BONDO???
PostPosted: Wed Jun 30, 2004 1:16 am
bondo will crack on you. you talkin about small dings in the metal that are too small to get out? thats the problem i have. i'm fixing mine right now.
try a product called (EVERCOAT formula 27). i did alot of research on this stuff before i started working on the dents. shit works great. everybody that has ever used it raves about it :) it's a great metal filler thats easy as hell to sand down to want you want :D
go to yahoo and type in the search. if you do use the stuff make sure you order enough. your not going to find in any store and shippings alot since its a hazzard material. try shipstore.com. shipping is cheap too :D evercoat has any kind of product you need. check into the stuff :D
PostPosted: Wed Jun 30, 2004 1:19 am
http://www.shipstore.com/ss/html/FIB/FIB570.html
PostPosted: Thu Jul 01, 2004 9:20 pm
yes thats it the rust ate littel tiny pits in the metal and they are too small to sand out and the ruff surface would look terrrible with new paint.
this will fill in the holes and won't chip out? how does paint stick?
How much would i need? the area is propaly total about in between 1/4 and 1/2 of the body
thanks alot
PostPosted: Fri Jul 02, 2004 12:15 am
i used a pint of the stuff. 9.99. that was enough to do both sides of the bed, tailgate, and 2 dents in the fenders.
i highly suggest this stuff :D doesn't crack, shrink or fall off. very very easy to use and easy to sand with 100 grit. you just fill over just a little more than the dent and then sand down to smoothness :D
i searched through hundreds of products and decided to go with this stuff.
(one thing you'll need is some extra white mixing hardener. remember this cause you WONT have enough by a long shot..)
one good thing is you can order color sticks for this stuff so you can lay it on with the color of your car so you don't need to get a paint job.
here's the pint
http://www.shipstore.com/SS/HTML/FIB/FIB571.html
here's the hardener
http://www.shipstore.com/ss/html/FIB/FIB340.html
this shipstore is the cheapest place your going to find to ship, so i'd go with them.
hope this helps
here's what i had.
here's now :D
