It is currently Sun Jun 07, 2026 9:30 am
 Post subject: is it just me!?!?!
PostPosted: Wed Jun 09, 2004 3:11 am
For the life of me I cannot find a plug for my exhaust manifold to plug the hole where the egr pipe was going to the intake! Can someone give me some guidence here? Im having to drive my truck around noisy as hell and backfiring and idling screwed up...VERY ANNOYING!!! Not to mention every cop that passes me looks at me real close and half of them flip a bitch to follow me...
PostPosted: Wed Jun 09, 2004 3:36 am
I think I have one on the motor I just pulled. If so it's yours. Give me a day or 2.
PostPosted: Wed Jun 09, 2004 7:13 am
Luvtruck.com Wookie
hey luvnit do you have the specs for that bolt? i can't find anything to plug mine either.....I have it pinched off and soldered and it's in the way. it would be alot easyer to find one if i knew what i'm looking for.
TiLtEd wrote:
Boobies!!! :D
PostPosted: Wed Jun 09, 2004 11:42 am
I am glad the truck that I got was very nearly complete. I adjusted the valves, but there is still a tick, but it is not as predominant now. But other than that, she hits the road FRIDAY!
PostPosted: Mon Jun 14, 2004 8:38 pm
Diarmadhim has first dibs on it, but I will try to get the specs for ya.
PostPosted: Tue Jun 15, 2004 5:30 am
why not me? i made the post? I been driving around backfiring forever! )-: Oh well, at least someone could get some specs here?
PostPosted: Tue Jun 15, 2004 6:41 am
Why not take the head off, and solder the hole shut? It would seem that it would be metric, something the size of a oil pan bolt.
PostPosted: Tue Jun 15, 2004 6:55 am
Sorry bud, but when I posted that Dennis reminded me that he told me once that he wanted it. Must of been drinkin that night. Anyway gonna get those specs in a day or 2
PostPosted: Tue Jun 15, 2004 12:18 pm
I'll see what I can find out today, when I go into town.
Resident lurker
PostPosted: Tue Jun 15, 2004 3:49 pm
heres the beast solution, its called a header. Driver FX caries Pace Setter ones 8) :lol:
PostPosted: Tue Jun 15, 2004 9:42 pm
do you loose low end torque with a header? I was considering not doing a header for fear of loosing torque. Whats the cheapest for a header neways?
PostPosted: Tue Jun 15, 2004 11:28 pm
Luvtruck.com Wookie
try this nate......#70-1105
http://www.pacesetterexhaust.com/pricing.htm
TiLtEd wrote:
Boobies!!! :D
PostPosted: Wed Jun 16, 2004 2:18 am
wow....i think i'll watch ebay for one....seen them on there for wayyyy cheaper...
 Post subject: Header link
PostPosted: Wed Jun 16, 2004 8:16 pm
Theres a header with no coating and one with coating on this site:
http://www.pacesetterexhaust.com/headers_truck.htm
PostPosted: Fri Jun 18, 2004 3:08 pm
thats the header i am running and i love it. I have 2" pipe whith a cherry bomb for the exsaust and it performs great. Whith the other stuff done to my motor i didnt notice any loss of low end but a 4banger inherently wont make power untill at least 3,000rpm. My truck pulls strong from about 2,000to 6,000rpm. Only hitch i had whith instalation was having to grind the little hook for the clutch cable off the bell housing to clear the collector, and it took a short section of flexable pipe to clear that first crossmember.
 Post subject: Specs
PostPosted: Sun Jun 20, 2004 3:28 pm
Not to be impatiant, but did you find the specs for that bolt?
(With this post I'm now a guru, wahoo! 8) )
PostPosted: Sun Jun 20, 2004 8:37 pm
Well Dennis came and got that bolt which was actually not a bolt, but someone had cut off the pipe where it went in to the bolt and welded it closed, Dennis did go to town to try and find a bolt that matched but had no luck. Maybe he will fallow up on this post and let you know more.
PostPosted: Sun Jun 20, 2004 8:59 pm
Zane, I couldn't find anything in town. However, I have the tube on my parts truck. I will try and weld one of the buggars closed and see what happens. I'll send one to you if I can do it without mucking it up.
Resident lurker
PostPosted: Mon Jun 21, 2004 12:04 am
just had an idea i thot i might throw out. I was going to take the part that originally screws in and take it off the tube and see if I could get the hole in the nut that holds the pipe on tapped to put a more easily found bolt in it. Dont misunderstand me talking about retapping the hole in the manifold. Tap the whole in the nut and plug it with a bolt and put it back in. Might be possible, the machine shop i went to just didnt have a big enough tap.
PostPosted: Mon Jun 21, 2004 9:27 am
Never thought of that, I actually might see about that before I weld it closed.
Resident lurker
