It is currently Sun Jun 07, 2026 7:30 pm
 Post subject: overdrive?
PostPosted: Wed Apr 28, 2004 11:59 am
ok so im rephrasing my question i guess. I really wanna find some kind of overdrive for my 79 4x4 luv...i guess someone makes these things and they fit between your tranny and driveline? Anybody know if someone makes these for the luv at all ever or anymore?
PostPosted: Wed Apr 28, 2004 12:11 pm
http://www.gearvendors.com
Looking for a LUV in NC. gimmie...
PostPosted: Wed Apr 28, 2004 12:34 pm
they dont make one for the luv tranny
PostPosted: Wed Apr 28, 2004 2:24 pm
werent there some old school GM rears that were 2 speeds (high and low)?
PostPosted: Wed Apr 28, 2004 2:32 pm
I do believe so but dont quote me on that though.....
PostPosted: Wed Apr 28, 2004 2:37 pm
G.M. did use two speed rear ends, but they were big units for school buses, 1 1/2 ton and better work trucks, and so forth. Not something you would want to try and adapt into a luv.
PostPosted: Wed Apr 28, 2004 2:43 pm
Yeah definetely not a good idea then.... :lol:
PostPosted: Wed Apr 28, 2004 10:21 pm
you might try and find something that's divorced from the transmission. that way it could bolt up easily. not sure if an OD like that exists though...
PostPosted: Thu Apr 29, 2004 8:39 am
Back when I was putting Detroit Diesels in pickups, there were two different "splitters" we would use. The first was the Spicer, which had underdrive, straight, and overdrive, and was installed midway between the tranny and rear end. This would not be a good option even if you could find one, as they are about the size of a large three speed tranny, and were $2500 - 3000 twenty years ago. The other item we used was a Ranger overdrive, which was straight and overdrive, and installed between the bellhousing and transmission. I don't know if these are even available anymore, but it might be an option to look at, although they were also a little pricey.
PostPosted: Thu Apr 29, 2004 12:42 pm
ranger overdrives are still made. but since they fit between the bellhousing and tranny, you'll probably need a more common american transmission(like a muncie, t10, th350 etc)
PostPosted: Thu Apr 29, 2004 9:11 pm
You might want to search the other posts for the topics dealing with putting a Trooper tranny into the LUV. It is a 5-speed and of all your options, it has the least amount of mods you'd have to do. From what I understand, the Trooper tranny from its early years was very similar to the LUV tranny except with a 5th gear (i.e. overdrive) grafted on. That made it a little longer and there are a few things you'd have to modify but overall I think its the least expensive and least work-intensive option you've got.
I don't know how big a difference having the 4x4 makes when it comes to that swap, but I can't imagine its much. You may need to have a custom driveshaft made for either the front or rear depending on just how the tranny sits. If I were you, I'd head to a junkyard with a camera and measuring tape and jot down some notes about tranny length, crossmembers, driveshaft lengths, etc.
Sorry for the long post but I hope that helped you out a little bit...
PostPosted: Fri Apr 30, 2004 12:40 am
ive heard of a 2 speed diff, i know they are not cheap and wouldnt have a clue where to get one but i think they have em on some 4wd's
PostPosted: Fri Apr 30, 2004 2:20 am
a 2 speed differential isnt really an option since im putting in a lockright. But about the 5 speed trooper tranny? Has anybody done it? I have heard they mount up too much differently to work!?!?
