It is currently Sun Jun 07, 2026 10:50 am
 Post subject: gear shift boot
PostPosted: Mon Apr 12, 2004 12:24 pm
Anybody got any ideas where to get the rubber boot that slips over the gear shift and attaches to the tranny hump part of the floor board? My parts source at the Chevy dealer says it's a discontinued part. I haven't been to the junkyard yet. Would one from a trooper maybe fit?
PostPosted: Mon Apr 12, 2004 12:41 pm
Sometimes if you look around (might take some looking) you can find a universal one thats almost identical. Like I said though, it might take some looking. I found most shifter boots I ever needed at Princess Auto, but I don't think you guys have that store in the US.
PostPosted: Mon Apr 12, 2004 1:08 pm
jc whitney sells typical rubber shift boots for around 20 bucks or so
PostPosted: Mon Apr 12, 2004 1:20 pm
lemme look I think I have an original that isn't torn.....maybe....
03Cobra
PostPosted: Mon Apr 12, 2004 7:52 pm
trooper wil fit, just pick one up at the junkyard 8)
PostPosted: Mon Apr 12, 2004 11:27 pm
I think in 78 or 79 the shifter on LUVs changed a bit. My 77 has a thin shaft all the way down into the tranny, and my 79 has a short stubby shaft that goes into the tranny and a fatter shaft that hooks over it. Niether of them has a boot that quite matches my trooper, but the trooper boot would probably fit the later style LUV shifter ok.
I'd just start hitting the yards and see what you can find. Take a measure of the hole in the floor and look for something around the same size in whatever rig you can find. If you happen to spot a good one in a LUV, then great, but I bet there is something out there that would fit just as well.
