It is currently Mon Mar 23, 2026 7:16 pm
 Post subject: locker or limited slip?
PostPosted: Mon Apr 12, 2004 10:02 pm
Got a good deal lined up on a used Detroit EZ locker thatll save me $100. But at the same time I m thinking at $350 I could spend that $100 more for a brand new Auburn limited slip. What exactly are the differences? Maybe some good knowledge could help my decision.
PostPosted: Mon Apr 12, 2004 11:07 pm
Well first of all...... what kind of rearend are we talking? If I'm reading this right this guy wants $250 for a used locked? I paid $242 from 4wheelparts for a detroit qwik lock for a D44 on my cherokee. Second..... these kinda lockers a considered "lunchbox lockers" because they install into the stock carrier and do not require gear setup. You can install these at home without special tools. Third...... the auburn limited slip is its own carrier witch does require a gear setup. Not real cheap to have done unless you do it at home and really know what you are doing and have the required tools. Fourth...... I personally think the Auburn suck. They have clutches that will eventually wear out and cost more money.
PostPosted: Tue Apr 13, 2004 8:11 am
I have an open 8" ford rear end. Going in a 2wd drive Luv.
PostPosted: Tue Apr 13, 2004 10:55 am
detroit truetrac could be a good option. it's a decent limited slip, uses gears instead of clutch packs. unless you want to go to a full locker, get a full carrier replacement detroit. won't be fun on the street though!
 Post subject: What?
PostPosted: Tue Apr 13, 2004 9:05 pm
Is burning off one tire fun or something? I don't get it. I run a detroit locker in the 9 inch in my S10 and is driven daily on the street. No problems what so ever. I also have a detroit quik lock in the D44 in my cherokee whitch is also driven daily on the street. Only thing possible I can think of that would't be a good idea is a spool. More likely to break an axle running it on the street. :roll:
PostPosted: Wed Apr 14, 2004 9:07 am
I had a Trans Am that had an Aburn limited slip that would roast the s... out of both tires. A co-worker told me about a cheap locker that I need to check out. Doubt they have one for an 8" though. Not a very common rear for you wheelin guys.
PostPosted: Mon Apr 26, 2004 2:45 pm
i have a luv 4x4 with the stock axels, waht type are these? and do they make lockers for them?
PostPosted: Mon Apr 26, 2004 2:54 pm
I got a detroit locker in mine..... the only thing I would ever change is when I go to a SPOOL ...... gotta love them tire dealers
GOTTA GET A NEW LUV!!!!!!!!!
PostPosted: Mon Apr 26, 2004 6:25 pm
the only available locker for the luv rear is the lockright...nothing for the front though
PostPosted: Mon Apr 26, 2004 7:02 pm
is that a selectable locker, like an ARB? or is it automatic?
PostPosted: Mon Apr 26, 2004 9:31 pm
Check out ringpinion.com. They had an awesome selection for the 8". Didnt check for a Luv rear as mines goin bye bye.
PostPosted: Tue Apr 27, 2004 12:53 am
lockrite is an automatic lunchbox locker, which means you just have to replace the spider gears with the locker guts
PostPosted: Wed Apr 28, 2004 12:49 am
Did any Luvs come with limied slip stock? The previous owner dint know much about mine. When I had it on jackstands I noticed the other rear tire spining.
Can one of you guys get me a link for the Lockrite. I wann do some pricing.
PostPosted: Sat May 01, 2004 8:33 pm
LUVs did not come with a limited slip stock ever, but the same rear was used in Isuzu Impulses. The turbo Lotus tuned Impulses did come with a Powerbrute limited slip that will fit the LUV rear end. Good luck finding one though.
