It is currently Mon Jun 22, 2026 10:55 pm
PostPosted: Mon Mar 29, 2004 10:15 pm
I have a lot of slop in my gearbox and was wondering if there is anyway to fix or replace the gearbox. I am looking for the least expensive fix since the 4x4 is only a hunting truck.
PostPosted: Mon Mar 29, 2004 11:15 pm
if you have manual, pull it apart carefully and see if you can figure out whats wrong, if there are any striped gears etc..
PostPosted: Mon Mar 29, 2004 11:24 pm
There is an adjustment that you can tweak, but if a gear is popped loose or stripped, hit the boneyard and grab ya a box out of a Isuzu Trooper (84 model or so), or an Isuzu Pup.
Same gearboxes. You may have to do some adjusting and a re-alignment tho.
PostPosted: Mon Mar 29, 2004 11:26 pm
Have you tried adjusting the play out of the steering gearbox with the adjusting screw on top? Don't turn it too tight. You can practically lock the steering up with the adjusting screw.
PostPosted: Mon Mar 29, 2004 11:31 pm
I have tried to adjust the screw on top with minimal success and have had it lock up on me. I have heard that the design of the gearbox is bad and don't want to waste money on the same designed gearbox. Are the later model boxes better and how much will it run me to get one at a bone yard?? Do they match up with the exsisting bote holes?? thanks for the help!!!
PostPosted: Tue Mar 30, 2004 1:06 am
might whant to top off the fluid. On mine it was realy loose so i adjusted it up and filled it up and its great now. Theres a small squard plug next to the adjustment screw. pop that off and fill it up whith 90w gear lube. And if you need a steering box i have a good one on my 78 LUV i would sell you for cheap. Let me know!
PostPosted: Tue Mar 30, 2004 6:37 am
that looks like a good answer if it is still being a fuss.
8)
LUVTRUCK.COM RULES!
03Cobra
PostPosted: Tue Mar 30, 2004 8:01 am
PostPosted: Tue Mar 30, 2004 7:02 pm
yup this site is awsome. Have a problem, make a post get help and even get parts! :lol: 8)
PostPosted: Tue Mar 30, 2004 10:43 pm
i had alot of slack in mine and i adjusted the gearbox and it helped a little, then one day i was under the truck and noticed i had a bad idler arm and bracket. they were real loose. i replaced them and now i don't have any slack. the whole time i thought all the slack was in the gearbox.
1980 chevy luv 4x4 1.8 liter
1979 luv long bed parts truck
PostPosted: Mon Oct 25, 2010 4:41 pm
I feel like I must be crazy because my steering gear does not have a fill plug. IS this common for the 80s and 81s? My steering gear is making noise and won't pass inspection so I wanted to try to fill it up but there is no plug from what I can see. Any thoughts anyone?
PostPosted: Tue Nov 02, 2010 2:23 am
yeah i think alot of the parts on the 80-81(especially the 4x4) tend to be slightly different. O'Wrongley's stocks the wrong oil pressure sending unit for my truck, but i'm not even sure the 81 pup one i got is the right one either. but its working.
1980 Chevy Luv 4x4 mikado factory Black.
1.8L 4spd
PostPosted: Wed Nov 03, 2010 5:33 am
Power steering?
Users browsing this forum: Baidu [Spider] and 37 guests
