It is currently Sun Jun 07, 2026 9:32 am
PostPosted: Tue Mar 23, 2004 9:46 pm
I tore apart my distributer off my 79 luv to clean it up and make sure everything was working smooth. Well i pulled out that plate the points sit on which is suppose to spin some on bearings to advance it i think. Well it doesnt turn very easily...its kinda rough. I was wondering if this might be causing my truck to run poorly. When i accelerate most of the time its kinda is slow to start and then just takes off real fast...was wondering if that could be the cause...also wondered if i do a ignition swap with a xr-700 or xr-3000 electronic ignition does it advance electronically or does it use the vacuum advance still?
PostPosted: Tue Mar 23, 2004 10:58 pm
There's a set of centrifugal weights that will advance the timing against springs. Vacuum as you open the throttle will also advance the timing. It takes firm pressure on the breaker plate to rotate it. Rough is a subjective term. To me it means uneven. That would be unacceptable.
PostPosted: Tue Mar 23, 2004 11:51 pm
well when i had it out i would grab the center part and turn it and it would felt as if the bearings had a bunch of flat spots and sometimes it would catch. The thing doesnt even turn that much tho does it?
PostPosted: Wed Mar 24, 2004 9:17 am
No, the breaker plate won't turn a full circle. Doesn't have to. Only enough to change the timing to accomodate engine RPM. I'd estimate somewhere in the area of 25 to 35 degrees. But it sounds to me like you need a new distributor. Sounds like a good time to change over to electronic. My Mallory Unilite has vacuum advance. Cost me right at $300. Worth it to me. I hate points. Grew up having to adjust them. If LUV points had an oil wick on the breaker plate for shaft lubrication, it would be a better design.
PostPosted: Wed Mar 24, 2004 11:01 am
mine has a wick for lubricating the shaft...still turns rough tho...
PostPosted: Wed Mar 24, 2004 11:18 pm
Nate
Where'd you get the points? I tried a number of places up here and nobody had points with a wick. Not that I need points NOW.
PostPosted: Thu Mar 25, 2004 12:22 am
lol, um the new points didnt come with a wick i used the old one and just put more grease on it. I got my points from autozone.
