It is currently Sun Jun 07, 2026 2:05 pm
 Post subject: Cibie Z beam
PostPosted: Thu Mar 18, 2004 10:59 pm
ever heard of these lamps? Any good?? What have all u guys done for different head lamps? I notice these old headlamps arent nearly as bright and outstanding as newer cars...would be nice to have something better i think.
PostPosted: Fri Mar 19, 2004 12:46 am
Autooptiks.com(i think) has composite headlight shells that will fit in the benzels of early and late model Luvs. I bought a set and rewired my truck with heavier gage wiring and relays. They take the H type bulbs that use the stock lamp connectors and they are really bright! You might want to look at them before you decide on what you want to do.
PostPosted: Fri Mar 19, 2004 6:46 am
hella also has these lamps. I have them in my truck.
got them from http://catalog.com/susq/index.htm.
edited to say definitely if you go with a higher wattage to re-wire the headlights.
I have done this also.
03Cobra
PostPosted: Fri Mar 19, 2004 2:09 pm
hella makes a sealed beam replacement that uses H4 bulbs. fit's right in just like a regular headlight, but bulbs are much cheaper and brighter than stock
i think they go for around 70 bucks a set
PostPosted: Mon Mar 22, 2004 1:27 am
would the 50 amp luv with ac alt. hold up to 100/80w Xenon White XB +100% H4 Bulbs!?!?! I have the 50amp alt. but i dont have/use ac. So only thing that runs off it is normal lights/ignition and anything else im forgetting that comes stock which takes electricity...whats everyone think?
PostPosted: Mon Mar 22, 2004 6:43 am
yes, but you have to use larger wire for the headlights. it will fry the stock wiring.
03Cobra
Users browsing this forum: Bing [Bot] and 15 guests
