It is currently Sat Jul 04, 2026 3:40 pm
 Post subject: s-10 frame
PostPosted: Thu Mar 11, 2004 7:25 pm
I heard that a luv will fit on an s-10 frame with some modifications. I thought about getting a donor s10 with the 2.2 l engine and ditching the body and using everything i can from it oon the luv. Will a 94 and up s10 work or does it have to be an older model?
PostPosted: Fri Mar 12, 2004 10:58 pm
i would guess that the older s10 would be very similar to the luvs, but the newer frames would require quit a bit of fabrication. might be easier to stick the 2.2 in the luv.
1980 chevy luv 4x4 1.8 liter
1979 luv long bed parts truck
PostPosted: Sat Mar 13, 2004 10:22 am
The 2nd gen s10 frames are very similar to the first gen frames only they have Better designed torsion bar mounts and frames are boxed.
I know a guy who put a '95 s10 frame under a '82 S10 with no trouble at all other than the bumper mounting brackets being different.
PostPosted: Sat Mar 13, 2004 1:46 pm
2wd S-1os have coil springs not torsion bars. Maybe 4wds do, wouldnt know, never owned a 4wd S-10. If you re looking to do a 2wd, it would be a good swap. Opens a whole world for easy suspension mods with all the bolt on bag stuff thats out there.
PostPosted: Sat Mar 13, 2004 1:52 pm
Hmm..for some reason i just assumed that he was wanting a 4x4 frame.
Since he said its got a 2.2 on it he's talking about a 2wd frame. (thats what i get for not reading well before i reply) :roll:
2wd S10s have coil springs
4wds had torsion bars
