It is currently Sun Jun 07, 2026 10:51 am
 Post subject: Trouble with front cover
PostPosted: Tue Feb 24, 2004 10:33 pm
Im having trouble getting the front cover off the engine. The engin is on the ground and all the bolts are loosened but it wont come off. Is it just stuck or did i miss some bolts?
PostPosted: Tue Feb 24, 2004 11:02 pm
if the crank pully and watter pump are off then it should come off. Try using gentle presure whith a pry bar. The bolts on it should be rather apperent, if its not realy clean try cleaning it well...
PostPosted: Wed Feb 25, 2004 6:30 pm
it won't come off unless the oil pan is off. you didn't say whether you had it off or not so i thought i'd mention it.
1980 chevy luv 4x4 1.8 liter
1979 luv long bed parts truck
PostPosted: Thu Feb 26, 2004 12:10 am
no the oil pan is not off, but i'll take it off and see what happens..thanks
PostPosted: Thu Feb 26, 2004 2:03 am
the oil pan needs to come off to get the timing cover off.
PostPosted: Thu Feb 26, 2004 2:48 am
huh i guess i just didnt remeber that the front cover interfaced whith the pan. :oops:
PostPosted: Sun Feb 29, 2004 4:23 pm
does the head need to come off too?
PostPosted: Mon Mar 01, 2004 8:09 pm
yea it has to come off too. replacing the timing chain is basically a complete tear down of the motor.
PostPosted: Tue Mar 02, 2004 3:53 am
you shouldnt need to pull the head, just take off the rocker cover and undo the bolts to the timeing cover
PostPosted: Tue Mar 02, 2004 7:29 pm
sorry about that, from what i remembered i thought the head had to come off.
PostPosted: Tue Mar 02, 2004 9:44 pm
it shouldnt matter, unless you have to lift the timing cover up to take it off
PostPosted: Wed Mar 03, 2004 8:56 pm
seems like i remember 2 bolts down kinda where the timing chain goes down into the head. you have to take the valve cover off to get to them but i think your right about the head.
