It is currently Sun Jun 07, 2026 9:21 pm
PostPosted: Mon Feb 23, 2004 11:23 pm
ok one of my friends got a 400 small block that run great .. But im not sure about the 400.. theres something diffent about them Than a reglar 302-350 smallblock.. maybe its the heads or something .. Will they line up the same as a 350?.. do they weight lot more ? you can make a high Rever engine with a 350 crank in a 400 .. What Do you guys think about a 400 ? heard they run like a raped ape :P
PostPosted: Tue Feb 24, 2004 7:07 am
A 400 is a good engine, I was gonna put a 400 in my truck, but the engine was screwed so it never happened. As for fit, its a SBC, so it's identical to a 350, 327, 283, etc. dimension wise. The 400 is not really known for revving...but...its a small block...it'll take it! :P
PostPosted: Tue Feb 24, 2004 12:39 pm
A 400 is balanced different than the other small blocks but dimensions are the same.
 Post subject: Small block
PostPosted: Tue Feb 24, 2004 1:01 pm
The small block chevy's were basically the same identical block, plus or minus the bigger bore and longer stroke.
PostPosted: Tue Feb 24, 2004 4:24 pm
Yeah the 400 has different balancing externally, but nothing that is gonna affect anything on a SBC install.
PostPosted: Tue Feb 24, 2004 8:11 pm
ok , thanks... im highly thinking about buying it . how could i cheek and see if it has 4 bolt mains Besides droping the oil pan ? is ther a simple way to tell ? maybe a vin number or something
 Post subject: Mains
PostPosted: Tue Feb 24, 2004 8:41 pm
I don't belive there is any other way to tell whether it is a two or a four bolt main without looking.
PostPosted: Tue Feb 24, 2004 8:46 pm
If you run the numbers and find the right website, you should be able to get that info from the VIN numbers. Try it and see...
 Post subject: small block
PostPosted: Tue Feb 24, 2004 9:22 pm
The 400 was a big small block. It was known for blowing holes in the water jackets. It had a good sized bore. Although most people thought of it as the 502 of small blocks. You want a high revving motor, try a 350 block with 327 crank and rods. Make a long stroke out of a short stroke block.
PostPosted: Tue Feb 24, 2004 10:11 pm
if i am not mesitaken, i think that a 400 is a little bit different block. i think that they have 10 soft plugs instead of 8. two in front, two in back, and three in each side instead of just two.
PostPosted: Tue Feb 24, 2004 11:06 pm
lol ok... hmmm.. What is a soft plug lol .. is that like a freeze plug or something ? lol
PostPosted: Tue Feb 24, 2004 11:37 pm
yep, soft plug, freeze plug. same thing.
Resident lurker
PostPosted: Wed Feb 25, 2004 12:10 am
Look at the serial number and the casting number. Do a search on small block chev* casting numbers, and serial numbers. This should tell you if it is a two or four bolt. I wouldn't worry if you get a 2 or 4 bolt 400. If you buy the 400 make sure you get the harmonic dampener and the flex plate or flywheel with the engine. As previously mentioned the 400 is the only externally balanced small block. The heads used on a 400 must have "steam holes: drilled in them. The cast crank and short connecting rods don't make a high revving engine, but they make great torque. You can put the crank and rods from a 350 into a 400 and still use the 400 pistons. You must use special spacer main bearings. I don't think this is a great combo for the street.
PostPosted: Thu Feb 26, 2004 11:30 pm
hmmm tnx.. .... i gotta quit dreaming... A I ether gotta get the luv runing my grandam so i cant have a ride to work and back. luvs giveing me all kinda problems... grandams torkcoverter is out lol.. i only got like 8 bucks lol sooo YA.. Cant make the sceen if you dont got the green lol ...
Users browsing this forum: Baidu [Spider] and 47 guests
