It is currently Sat Jun 06, 2026 10:31 pm
 Post subject: heater core
PostPosted: Wed May 02, 2018 9:21 pm
Finally got heater fixed can anyone tell me what heater core hose goes where
Preston
 Post subject: Re: heater core
PostPosted: Thu May 03, 2018 1:15 am
Driver's side goes to the control valve. And I do believe the passenger's side goes to the back of the head.
PostPosted: Thu May 03, 2018 7:30 pm
Maybe this pic will help.
http://carphotos.cardomain.com/ride_ima ... iginal.jpg
PostPosted: Thu May 03, 2018 10:59 pm
Sorry I can't tell in pick. What hose goes on top
Preston
PostPosted: Fri May 04, 2018 12:28 pm
Just realized you're talking about an 81 Luv. Had to look at your forum name to deduce that as there was no info given in your post.
Sorry, I have no help for you on this one as I've never worked on the Pup versions.
PostPosted: Fri May 04, 2018 1:11 pm
I'll see if I can get a good pic this afternoon. My '83 P'up is the same.
PostPosted: Sat May 05, 2018 4:14 pm
Here's the best pics I could get without removing the air cleaner. If you click on each image, it should appear right-side up.
PostPosted: Fri May 11, 2018 2:07 pm
Thanks guy got it hooked up and it started leaking again back to the drawing board
Preston
PostPosted: Fri May 11, 2018 2:50 pm
In case you didn't know--
I tried for a long time to find an aftermarket source for these cores. I came up empty.
I know a guy who can get brand new ones from Isuzu, but they're over $300.
The next best thing is a salvaged core from an Isuzu Trooper (1984-1991, but preferably the newest one possible). It's a different factory part number, but the core is a perfect replacement for the original.
