It is currently Mon Jun 01, 2026 2:11 pm
PostPosted: Wed Aug 07, 2002 2:52 pm
Replaced all the usual electrical stuff and the fuel pump -- any tricks on tuning the carb on a 76 Luv? truck :cry: used to run fine until the fuel pump failed now needs a lot of gas pedal action and has a hard time starting cold and warm lots of cranking and will stall.
PostPosted: Wed Aug 07, 2002 3:50 pm
sounds like you need a new accelerator pump to me. :twisted:i would just put a complete kit in it. you might have some varnish buildup in the idle passages from sitting. so let it soak in some carb cleaner.my . :roll:
PostPosted: Fri Aug 16, 2002 9:35 pm
OG Lifer
mine was doing the same thing. when i disassembled the carb and started looking for cracks and such, i found a build up of black carbon looking stuff in the primary and secondary air bleeds. it still runs slightly rough but it runs 10 times better. i also had to replace the fuel pump relay(universal relay at autozone) and the inlet filter screen. seemed to help alot.
PostPosted: Tue Oct 29, 2002 10:05 am
i put i new carb on mine from n.a.p.a it runs a whole lot better but runs a little rough untill it gets warm. make sure u check the timming 12 degrees of timing for the 1.8 liters.
PostPosted: Fri Nov 01, 2002 8:16 pm
hey try taking off your carb and turn it upside down and adjust the float clearance for the stock 4 cyl it is.060
1975 luv V-8 muncie 4 speed
