It is currently Tue May 26, 2026 9:34 am
 Post subject: Bed removal
PostPosted: Tue Feb 28, 2017 2:03 pm
Hello to everyone here.My first post here and i would like to ask you how can i remove the bed from a luv truck?How many bolts are there and what else do i have to do to take it off?Also about how much does the bed weights?Is it an one guy job?
 Post subject: Re: Bed removal
PostPosted: Wed Mar 01, 2017 5:54 am
I believe there are 8 bolts. Before you get started spray penetrating oil on them and let it sit for a while. While it is not to heavy you better get help as it is to big to take off with out damaging it.
PostPosted: Wed Mar 01, 2017 6:40 am
I was able to hoist mine off by myself by screwing hooks into the ceiling joists, and using cam straps to gradually shimmy it up far enough to clear the frame. Its not heavy at all compared to other truck beds.
PostPosted: Sat Mar 25, 2017 11:23 am
My bed is completely rusty.I found one from a kb20.Do you know if the frame mounts are the same in both of them?
PostPosted: Sat Mar 25, 2017 11:24 am
PostPosted: Sat Mar 25, 2017 3:07 pm
Are they both long beds? The long bed and short bed are not interchangeable.
PostPosted: Sat Mar 25, 2017 3:34 pm
yes they are both longbeds
