It is currently Sun Jun 07, 2026 6:56 pm
 Post subject: Squeeling Clutch
PostPosted: Sat Jan 17, 2004 4:47 pm
Just replaced clutch assembly in my 1975 Luv.
Clutch seems to be working fine, but there is a loud squeel when I engage the clutch.
Does anyone have any ideas why?
Thanks, Todd
PostPosted: Sat Jan 17, 2004 6:21 pm
OG Lifer
Did you put it in backwards?
WATCH YOUR PIEHOLE!!!!!!
PostPosted: Sat Jan 17, 2004 7:04 pm
You took the words out of my mouth. It sounds like it may have been in backwards, or it was improperly torqued. Those are the only things I can think of, or the cable needs adjustment.
PostPosted: Sat Jan 17, 2004 7:12 pm
does it squeel every time you use the clutch, it did it on mine i just used to pump the clutch a few times and it stoped, my problem was due to a worn pressure plate
PostPosted: Sat Jan 17, 2004 9:52 pm
double check and make shure its in right and everything is torqued corectly. That and also check the through out bearing.
PostPosted: Sun Jan 18, 2004 12:13 pm
my friends luv did that exact same thing and it turned out that when he replaced the clutch, he installed the throwout bearing backwards.
1980 chevy luv 4x4 1.8 liter
1979 luv long bed parts truck
