It is currently Fri May 22, 2026 10:28 pm
Post new topic Reply to topic  [ 37 posts ]  Go to page 1, 2  Next
 Post subject: New Luv Owner in the PNW
PostPosted: Thu Jul 07, 2016 11:11 am
Hello All,
Just picked up my 1978 Chevy luv Mikado stepside. Runs n drives got it for a steal of a deal. Just needs a carb rebuild or tune up, idles rough and stalls also sputtering at low rpm. Then misfire going about 55-60 mph unless I'm coasting haha. Still working on naming this luv.
It has about 82,xxx miles (I dont know if it lapped over to 100k) but barely any rust mostly just surface rust. Deciding on which route to go with this project, I know I am not sticking with this 1.8L, need more power :D Missing a few odds and ends but most is complete.
Well this is all for now.
PostPosted: Thu Jul 07, 2016 12:46 pm
Welcome, Looks like a great truck to start with. 8)
PostPosted: Thu Jul 07, 2016 1:56 pm
Good lookin truck, the stepsides are getting more and more rare, always someone lookin for one
What part of the pnw are you in?
Many of us went with the more power route and got rid of the 1.8s. Couple options for mainstream swaps.
Isuzu 4 cyls 1.9 and 2.3
Buick 3.8 (older rwd ones not the fwd)
Smallblock chevy
Chevy 4.3 v6 the 3/4 350
Or pretty much whatever rearwheel drive 4 banger you feel like fabricating your own mounts for
PostPosted: Thu Jul 07, 2016 3:59 pm
Smallblock chevy
I am up north in Lake Stevens area. I maybe going to a 4 banger route as that is where I come from with my Eagle Talon AWD that I take to the track from time to time.
But for the mean time until I gather all the engine parts for the swap, I want this to run a little better to cruise around town etc.
Anyone local can help me out on rebuilding this carb or if any one has a carb that is good running condition? I have a spare carb that came with it. I am not a carb guy, more of a Fuel inj guy haha.
Can't wait to mod this beast of a truck!
PostPosted: Thu Jul 07, 2016 6:28 pm
Welcome !!
The factory carbs are garbage.
Swap it to a Weber 32/36.
PostPosted: Thu Jul 07, 2016 7:40 pm
Agreed the stock hitachi carbs blow. When i had the 4 banger i had a weber 32/36 and a p'up 1.9l electronic distributor and it was great for a g180.
Someone i cant remember who put a Sr20det in his luv and it was a ripper... I think the ka24e or de would be awesome for a pretty easy swap.
PostPosted: Thu Jul 07, 2016 8:54 pm
Someone has swapped with a Mitsubishi 4cyl turbo (Eclipse) engine in the LUV before.
PostPosted: Fri Jul 08, 2016 9:34 am
Would this Weber work for my Luv? I am still new to this Carb stuff.
http://skagit.craigslist.org/pts/5660027398.html
or what is a cheaper option? And anyone local willing to help out.
I will be looking into doing a 4G63T swap from a talon/eclipse (DSM). They do make adapter plates to mate to various transmissions like W58 or R154 or even the TH350 if I want to go auto, but looking to stick with manual.
PostPosted: Fri Jul 08, 2016 12:34 pm
Carb yes, adapter not likely
Redline weber sells adapters and carbs
They come up on here from time totime
PostPosted: Wed Oct 05, 2016 2:53 pm
Update:
Weber 32/36 installed, New coil, plugs, condenser, fuel filter, fuel pump, battery, valve cover gasket, etc. Added a semi-new bench seat, removed the ugly bucket seats. Cleaned out added new fuses to fuse box, connections were not too badly corroded. Resealed the sunroof, minor leaks.
Just need to add some gas and ready to roll for the past fuel months of being down.
Need to find a fan heater blower motor to fix my seized one before winter hits.
Pictures to come soon.
PostPosted: Wed Oct 05, 2016 9:26 pm
Any idea what that sunroof was originally from?
Waitin on pics
PostPosted: Fri Oct 07, 2016 11:27 am
Waitin on pics
Seems to me the sunroof look to be from the factory. As it fits in perfectly with the headliner.
more pics
PostPosted: Fri Oct 07, 2016 12:03 pm
Looking good. The sunroof is aftermarket, but could have been put on by the dealer. They made good kits back then. 8)
PostPosted: Fri Oct 07, 2016 1:24 pm
Ok sweet good to know!
PostPosted: Sat Oct 08, 2016 12:57 pm
Ripper86 wrote:
Welcome !!
3 rebuilds on mine. Still useless.
Does the carb kit come in a kit, or just bolt on? Never had any trouble with points. Is it worth $300 to go electronic?
PostPosted: Sat Oct 08, 2016 8:23 pm
Don't need $300 to go electronic get the ignitor kit from pertronix. Around $90.
https://www.summitracing.com/parts/pnx- ... /model/luv
For a weber carb need an adapter to go on your stock intake. Comes in a kit.
PostPosted: Sat Oct 08, 2016 8:28 pm
Nice truck mattp
PostPosted: Thu Nov 10, 2016 9:27 am
Update:
So I made a semi custom tonneau cover for my Tuff Luv stepside. What you guys think?
Came from a tonneau 3 piece cover from an avalanche or escalade. Bought it for cheap and decided to see if it will fit. It was 4 inches to short so I covered the rest with vinyl and magnets
PostPosted: Thu Nov 16, 2017 2:11 pm
Just wanted to share where my build is at so far with the LUV called Project CHEVISH.
See link below:
http://www.hotrodcoffeeshop.com/forum/v ... f=6&t=1703
