It is currently Sun Jun 07, 2026 7:29 pm
Post new topic Reply to topic  [ 165 posts ]  Go to page Previous  1, 2, 3, 4, 5, 6, 7 ... 9  Next
PostPosted: Sat Dec 05, 2015 7:58 pm
I'm sure they have the color or can make it. My guy couldn't get it from DuPont so I just picked something I thought was close.
Everyone has a story with their trucks/cars, good story.
PostPosted: Sat Dec 05, 2015 8:09 pm
I took my G200 engine and G180 head to the machine shop to get it rebuilt. Got to take the cam on Monday, I was running late so I didn't dig it up. I want the internals balanced so he asked me to bring him the flywheel and clutch. Hopefully it turns out good.
I also put in the sound insulation and threw the carpet on top and it doesn't fit right. Anyone know of a company that makes one that fits like it should? I bought this one on the Internet. This one will need a lot of work to look ok.
While I did that I also installed the steering wheel.
PostPosted: Sat Dec 05, 2015 8:29 pm
I 'think' all of the carpets come from the same manufacturer. I modded my trans tunnel and expect some issues due to that. A GOOD upholstery shop can fit what youhave. They have to cut and seam it. You can use the 3M spray glue and start in the middle doing a section atl the time and stretch it to the ends and trim if you're patient. You have to let the glue set before you do the next section...
PostPosted: Sat Dec 05, 2015 10:20 pm
Here is a picture of the box that fits 4 8" jbl subs. Installed with a 1000w rms pioneer amp and a high output alternator and the little truck bumps!
Yellow 74 LUV. Factory a/c
White 79 LUV. Factory a/c
Tucson, AZ
PostPosted: Sat Dec 05, 2015 10:32 pm
Dang, I'll try. Thanks
PostPosted: Sat Dec 05, 2015 10:34 pm
That looks like it restricts movement of the seat all the way to the rear. Does it?
PostPosted: Sun Dec 06, 2015 11:15 am
The seat slides back all the way without touching the subs/box. A lot of measuring went into the building of this box. I'm 6'3 and it would suck to not have the seat all the way back :lol:
Tucson, AZ
PostPosted: Mon Dec 07, 2015 1:04 am
Oh, very nice that it fits without having to put the seat forward. Thanks for sharing.
PostPosted: Mon Dec 07, 2015 9:05 am
when you glue that carpet down,don't use just any old 3M spray glue. I always had good luck with 3M 8090. It is [was] made for securing vinyl tops. It has an adjustable spray tip to change the pattern for the appropriate job. Follow the instructions on the can and it will de-laminate plywood before pulling off of the surface..
PostPosted: Mon Dec 07, 2015 12:03 pm
I LUV seeing all your doing to this LUV.....Thanks for sharing your progress.
When i re-carpeted mine a few yrs back i found an good deal on a new old Chevy kit on eBay i think it was late 60's
impala. 66-68 it was preformed for the hump and i positioned the heal pad and trimmed off what hung out the doors
and only put a few self tapping screws near the edge of the hump to hold it in place along w/ my shift hole plate and side
metal pcs and used some black felt material for the floor to finish up to the back wall since its under the seal & saved the
other of 1/2 of carpet to hang on the back wall.....(which wasn't done in these pics).... Here's a couple pics of mine
PostPosted: Wed Dec 09, 2015 6:18 am
I hope mine turns out that way, good job with yours. Thanks for the pictures.
PostPosted: Sat Dec 12, 2015 11:03 pm
Started to put the harness back in.
PostPosted: Sat Dec 12, 2015 11:04 pm
More
PostPosted: Sat Dec 12, 2015 11:06 pm
P
PostPosted: Thu Dec 17, 2015 8:40 am
Dash is here.
PostPosted: Thu Dec 17, 2015 8:45 am
Turned out great.
PostPosted: Thu Dec 17, 2015 8:47 am
A
PostPosted: Thu Dec 17, 2015 8:48 am
B
PostPosted: Thu Dec 17, 2015 8:50 am
C
D
