It is currently Sun Jun 07, 2026 8:20 am
PostPosted: Mon Jan 05, 2004 10:11 pm
ok... finally got it out.... welded it..... put it back in .... and it wont start ...
and there is 2 wires coming out of the ignition on is black with a white stripe, the other is black with a yellow stripe... i cannot find where they go!
Help please, my mother works up river, and its snowing and she needs my truck, so speedy replies please!?!?!
thanks
PostPosted: Tue Jan 06, 2004 12:15 am
Sorry if I missed something, but what is the "it" your talking about?
Resident lurker
PostPosted: Tue Jan 06, 2004 12:47 am
yeah im a bit confused as well. A little more info is in order here. :?
PostPosted: Tue Jan 06, 2004 1:35 am
i was reffering to my last post "I give up"
anywayz "IT" is the clutch brake pedal assembly
it broke so i had to take "IT" out and weld "IT"
PostPosted: Tue Jan 06, 2004 6:39 am
them wires are the neutral safety wires.
if the clutch isn't depressed the engine wont start.
if I remember correctly you can plug the wires into each other and it will start without having to depress the clutch.
03Cobra
PostPosted: Tue Jan 06, 2004 8:00 pm
Yep! Luv4me got it! I did that the first time I did mine too!! Why the heck wont my dam truck start????? Good thing I worked at a gas station at the time!
PostPosted: Tue Jan 06, 2004 8:07 pm
Becareful statrting it if you wire it direct. I had a buddy of mine do that in an old international and wound up driving it into the side of his parents garage. 8O 8O 8O :oops: :oops: :oops:
PostPosted: Tue Jan 06, 2004 9:21 pm
yup neuteral safety switch wires you got there. I just threw a jumper wire between the two of em 8)
PostPosted: Wed Jan 07, 2004 6:12 pm
Just to be clear, the clutch pedal depress safety switch is the two black with white stripe wires, and on my 79 there are two just alike. Might be another floating around, or the white may have gone yellow on one of them. I can't remember what black w/yellow is for, but the wiring diagram in the info section of the site should have. Anyhow, if they are not connected together, the starter will not crank. There should have been two switches on the pedal bracket by the clutch, one for clutch safety, the other part of the coasting richer system. I forget which is which. Probably got remove for the welding part. If they are both closed with the pedal in, it won't matter which one is which. If one is closed with the pedal up, that would not be the clutch safety one. I believe one has blade connectors and the other has round connectors though.
Just an FYI, I think this safety feature appeared in 78. Niether of my 77s have it, nor the 76s I've had. All the 79s I've had have it in there. Since so much else changed in 78 (and I've never had one) I'm assuming this bit came with the rest of the changes. I have it wired to a toggle switch, keeps people from borrowing my truck without asking. ;)
PostPosted: Wed Jan 07, 2004 7:23 pm
OG Lifer
On my truck, the black/yellow wire goes to the fuel pump relay. The black/white wire does too now that I remember.
WATCH YOUR PIEHOLE!!!!!!
PostPosted: Thu Jan 15, 2004 1:31 am
Thanks guys ... i finally got it all back together and running....
(knock on wood) i got to drive it to eugene and back :) doin fine.... even fixed the stereo
thanks for all the replies!
PostPosted: Thu Jan 15, 2004 1:32 am
Oh and if anyone would happen to have that switch extra pm me
and we can talk about a price ... dont like not having that switch .....
