Okay finally got around to getting the gas tank out of the LUV...
Easiest gas tank removal ever....
So first off, what is this? (Pic below... Located on driver side of the bed, behind a panel. 3 lines from the gas tank run to this.) Is it needed or can I bypass it?
^ I'm not sure what that is....
Anyways,
So I drained the gas out, was filthy. (Look in attached pics.)
What do you guys use when doing it yourself to clean the tank? I was thinking using a power sprayer and sticking it inside the filler neck/gauge hole and spraying it out then letting it drain, then adding some gas to it, slosh it around so it forces the water out, drain it and let it air out??
