It is currently Sun Jun 07, 2026 6:54 pm
 Post subject: Damn starter
PostPosted: Wed Dec 31, 2003 11:31 pm
great...so im delivering pizzas and i try to start luv and it just makes whirring sound.....the start spinning...Does it need new starter? Or is there something that makes the gears go together and engage to turn engine over. Any ideas on how to fix would be great....
PostPosted: Wed Dec 31, 2003 11:49 pm
if i am not mistaken, chevy starters have plungers in them that wiht electicity, goes in, and then it pulls on an engaging arm, it is kinda like a teeter totter only pulling instead of pushing, and then it pushes on the gear that rides on the flywheel/flexplate and engages it to the teeth on the flywheel. there could be something wrong in the electricle stuff in there or the engaging arm. once again, i am not positive on this, but we did study starters in auto shop and i took a few of them apart and put new brushes in them and etc,. you cane buy rebuild kits for them and stuff like that.
PostPosted: Thu Jan 01, 2004 12:23 am
OG Lifer
It's called a bendix drive. That is what you need to replace. Anymore, it is cheaper to just replace the entire starter with an overhauled unit.
WATCH YOUR PIEHOLE!!!!!!
PostPosted: Thu Jan 01, 2004 1:20 am
well thats simple enough....just replace starter....could it be anything else? Somethin in the engine? What caused it to make grinding noise when i tried to start it every now and then but only just lately....i sometimes turned the key and it'd make grinding noise and then would try again and would start fine. Just starter goin bad?
PostPosted: Thu Jan 01, 2004 4:12 am
well your fly wheel could be wearing. When you replace the starter shine a flash light in the hole and look at the fly wheel. If its all tore up you might whant to replace it. That is a big proces though, you would probly have to pull the motor. Good Luck
PostPosted: Thu Jan 01, 2004 12:19 pm
OG Lifer
What he said /\. If it is just slightly worn, I would just go with it. If you get a lifetime warranty starter, then I would try to make the flywheel last al long as possible.
PostPosted: Fri Jan 02, 2004 9:16 am
No man it is just your kick on the starter, dont worry about the flywheel they go bad about as often as you have a chance of falling in love with a donkey, You just need to get a rebuild kit for the starter. The grinding noise is more than likely just the starter trying to kick out to engage the flywheel.
PostPosted: Fri Jan 02, 2004 10:07 pm
Yep, NrdCouple advise sounds right. The part that goes bad normally is the starter solenoid. It's that little cylinder devise attached to the starter. Its purpose is to have a low current (amperage) control (starter switch or relay) to engage the starter drive to the flywheel. Starters are rated over 200 amps when engaged. The grinding or spinning sound is the starter pinion gear not being fully engaged to the flywheel, which is the job of the started solenoid.
The solenoid is a electro/mechanical plunger device that uses a lever/plunger to force the starter pinion gear into the flywheel, which closes a secondary set of contacts that goes directly to the battery, which powers the starter motor.
To ensure that your flywheel is not the culprit, get a larger screw driver or similiar tool and pry(move) the flywheel so that the started attempts to engage the flywheel at different location. Sometime flywheel can develope a bad spot on the gears. If the problem persist then change out the solenoid. The solenoid runs about $15-$30 verses a new starter $100-200.
Kaneguy.
PostPosted: Sun Jan 04, 2004 12:48 am
lol...get this...none of you were right. The dumb@$$ that put this truck back together fcked up the threads holding the starter on...so wudya know, the started dropped right out and sat down on my driveshaft....lol...luckily no harm was done by this...just had to rethread...
PostPosted: Sun Jan 04, 2004 12:59 am
LOL he could have at least welded a gear on the driveline so you could keep the starter engaged and move the truck!
Resident lurker
PostPosted: Fri Jan 09, 2004 7:14 am
Well hell, you got out of that cheep!
I know I had to have the capacitor replaced a few times with the Selinoid, but never heard of goofing up the starter threads.
Guy had to have been sik.
