It is currently Sun Mar 29, 2026 1:57 pm
 Post subject: 2.2 engine
PostPosted: Fri Jun 07, 2013 8:19 pm
Does anyone know or has anyone installed a 2001 2.2 dohc engine in a Luv?I have a complete car for parts. The engine is from a cavalier.
 Post subject: Re: 2.2 engine
PostPosted: Fri Jun 07, 2013 10:11 pm
That's not an Isuzu engine, is it?
PostPosted: Fri Jun 07, 2013 10:27 pm
he said its from a cavalier
PostPosted: Fri Jun 07, 2013 11:16 pm
Sometimes the problem with trying to swap a front wheel drive engine into a rear wheel drive vehicle is that there is no RWD tranny to go with that engine.
PostPosted: Sat Jun 08, 2013 12:52 am
Chevy used a 2.2 liter engine in second gen s-10s, I can't say for sure but I bet they are the same, so getting the tranny would be easy if you found a s-10 tranny for the same engine.
PostPosted: Sat Jun 08, 2013 6:56 am
I can read. I just don't know anything about Cavaliers. :)
PostPosted: Sat Jun 08, 2013 7:14 am
Starter is on oppsite side from the fwd to the s10 trans...
PostPosted: Sat Jun 08, 2013 8:00 am
The Hombre/Colorado 2.2L engine was made by Daihatsu & does not have a good reputation. I don't know if the Cavalier engine is the same.
PostPosted: Sat Jun 08, 2013 3:22 pm
Any 2.2l in a first generation chevy s10 is made by Isuzu according to what I read, than the second gen has a 2.2 made by chevy themselves.
PostPosted: Sat Jun 08, 2013 3:52 pm
Nope, first couple of years had the Isuzu, GM after that...
PostPosted: Sat Jun 08, 2013 4:33 pm
The only 2.2L I ever heard of in a 1st-gen S10 was the 2.2L diesel. I'm pretty certain the Isuzu gas engine was a 1.8 or 1.9.
PostPosted: Sat Jun 08, 2013 5:45 pm
i think the 2.2 in the cavalier is the same as the ecotec 2.2 you find turbocharged in baja buggies
http://www.ecotecforum.com/forums/showt ... -questions i think this site should have the info you need, i didnt look very far
