It is currently Wed Dec 17, 2025 1:31 am
 Post subject: 1982 LOV diesel
PostPosted: Fri Mar 22, 2013 8:23 pm
Need help Guys 1982 lov diesel tranny went to h*ll. no 5th, no 2nd, no 3rd. I haven't been unable to find a tranny for for it. So will other thing fit from other trucks? Thanks Norm
 Post subject: Re: 1982 LOV diesel
PostPosted: Sat Mar 23, 2013 3:33 pm
Read the first thread in the Drivetrain Upgrades section of this forum.
PostPosted: Sat Mar 23, 2013 4:10 pm
Norm, this happens to all of the '81-'85 LUVs. Where are you located? That will help us to help you find a transmission. I've replaced mine and I have a spare in the workshop that I couldn't resist (no, it's not for sale ;) ).
 Post subject: Hi joe
PostPosted: Sun Mar 24, 2013 9:03 am
I'm in Cullman, Alabama
 Post subject: Re: Hi joe
PostPosted: Sun Mar 24, 2013 3:31 pm
Your best bet is the Pull-A-Part in Birmingham. Do you ever get down that way?
You probably won't be able to find a diesel transmission. Fortunately, you don't have to. If your bell housing is still good, you can use a gas transmission (swap out the bell housing). Don't even THINK of using a pre-1986 transmission, they're prone to failures exactly like yours. Find one from a 2.3 gas engine from 1986-1995 and that's called an "UPGRADE". Unfortunately, it requires a different slip yoke (the front end of the driveshaft) and those yokes are getting really hard to find. I found one a couple of weeks ago and sold it here for $75. The other option is to CUT the yoke and U-joint off from whatever truck the transmission comes out of. That U-joint won't fit your driveshaft, so the yoke and U-joint and part of the shaft have to be spliced on by a driveline shop.
PostPosted: Mon Mar 25, 2013 9:25 am
Hi Jack
pullapart in B'ham I get in there about 6 or 7 times a year..........................Thanks Norm
PostPosted: Mon Mar 25, 2013 9:34 am
I'll keep my eyes open here. The last one I found ended up getting crushed. The previous one (in a 2.3 2wd Amigo) sat on the yard for 4 months, and then somebody needed it so I pulled it. It got crushed the same week. I hate seeing them get crushed!
PostPosted: Mon Mar 25, 2013 3:33 pm
Hi jack,
You stated You probably won't be able to find a diesel transmission. Fortunately, you don't have to. If your bell housing is still good, you can use a gas transmission (swap out the bell housing). Jack, tranny and bell housing are all one peice. Has someone put another tranny in it?..........Norm
PostPosted: Mon Mar 25, 2013 4:48 pm
namron4491 wrote:
Hi jack,
Norm,
"Bell housing" isn't quite accurate (I know, I'm the one who used that term). The bell is integrated into the entire front half of the case. There's a center plate that holds both shafts and all the gears. The front and rear halves of the case can be removed without any parts falling out. Your diesel front-half (assuming it's 5-speed) will bolt right up to the center section of the gas (2.3) 5-speed transmission. Finding a slip yoke is harder than finding a transmission.
The front case houses the input bearing. This input bearing often goes out in a big way. If not fixed promptly, it can damage the housing itself. Then you can't re-use the front case.
PostPosted: Mon Mar 25, 2013 8:28 pm
Jack, would mind leaving me a phone number and a time frame that I could call you, You seem to be very knowledge with these trannys..........Norm
PostPosted: Mon Mar 25, 2013 8:43 pm
Norm,
I have to tell you, I know how to swap them. To some people, swapping stuff makes you an expert. I disagree. I know some folks who have overhauled their transmissions, and even improved them. Now THEY'RE the ones who are knowledgeable.
But yeah, we can talk about how to swap them. I'll PM you.
