It is currently Wed May 27, 2026 2:11 pm
PostPosted: Sun Mar 03, 2013 11:31 pm
i went through about 12 pages and gave up
so my question is will a 75/76 engine fit or work in my 79 ?
found one but i dont know alot about the luvs so please any help would be great !
PostPosted: Mon Mar 04, 2013 12:33 am
A 76 and up motor will. The 72-75 motors are different.
PostPosted: Mon Mar 04, 2013 6:07 am
How would I tell the difference if I were to look at one pulled out?
And thank you very much
PostPosted: Mon Mar 04, 2013 10:56 am
'76 & later engines have the intake on the passenger side, exhaust on the driver side.
'75 & older engines have both the intake & exhaust on the same side, I think passenger.
PostPosted: Mon Mar 04, 2013 2:53 pm
75 and older have intake and exhaust both on the driver side (in the US anyway) or on the left side of the truck if you are sitting in the cab. The valve covers look quite a bit different too, black painted sheet metal is 76 and newer, unpainted cast aluminum is 75 and older. I bet if you look in the gallery on the main luvtruck.com site here you can probably find a 75 or older motor picture to compare.
