It is currently Mon Mar 23, 2026 11:14 pm
Post new topic Reply to topic  [ 24 posts ]  Go to page 1, 2  Next
 Post subject: not getting any gas
PostPosted: Thu Jan 03, 2013 7:31 pm
well my 78 luv isnt getting any gas too pum pfrom the tank, ive replaced the fuel pump,blown out the lines and did the filters but still nothing. i know the pump works cause i bypassed the tank by hooking the pump too the carb with a gas can. its gotta be the tank. is it clogged? what do you guys think is wrong?
I'm workin' on it
78 chassis with 75 cab
SBC
 Post subject: Re: not getting any gas
PostPosted: Thu Jan 03, 2013 8:30 pm
anyone?
I'm workin' on it
SBC
PostPosted: Thu Jan 03, 2013 8:35 pm
Sounds like the tank is plugged, mine and my dads luvs both plugged up in the tank from sitting so long. Try blowing air through the fuel line to the tank. My dads was so plugged, we had to drop the tank and remove the sending unit to get to the bottom of the line in the tank.
PostPosted: Thu Jan 03, 2013 8:36 pm
Tank needs to be pulled,flushed and sealed would be my guess.
Crap in my tank,hate that.
PostPosted: Thu Jan 03, 2013 8:39 pm
I need to learn to type faster :lol:
PostPosted: Thu Jan 03, 2013 8:59 pm
i did blow air through the lines and its still not flowing. how hard is it to remove the gas tank? do you have too take off the bed? it has been sitting for 5 years also
I'm workin' on it
SBC
PostPosted: Thu Jan 03, 2013 9:36 pm
air leak possibly?
I'm workin' on it
SBC
PostPosted: Thu Jan 03, 2013 10:04 pm
Sounds like you need to get inside the tank to get the gunk from under the line in the tank. (the black rubber fuel line in the pic)
Not real hard to drop the tank. Did my dads from underneath in about an hour, mine takes about 5 minutes with the tilt bed :twisted: ) 3 bolts on the front, 3 bolts on the back, 3 rubber vapor lines, 1 fuel line, filler hose and return line and fuel sender wire.
Here is a pic of mine with the bed off.
PostPosted: Fri Jan 04, 2013 4:15 pm
ok, thank you fr the info. im gonna go drop it and clean it. doesnt seem too hard, hopefully it isnt. what size are the bolts and where are they located?
I'm workin' on it
SBC
PostPosted: Fri Jan 04, 2013 8:47 pm
I dont remember but I think they are 12 or 11mm. There are 3 on the front of the tank and 3 on the back. The front lip of the tank sits on a support rail and the back bolts underneath the bracket so put a support (I used a floor jack) under the back of the tank so it dont come crashing down when unbolted. I hope you dont have a full tank!
I can go snap some pics from the other side if you need them.
PostPosted: Fri Jan 04, 2013 8:49 pm
i got all the bolts off and it is loose but it wont drop away
I'm workin' on it
SBC
PostPosted: Fri Jan 04, 2013 9:00 pm
Did you dissconect the fuel guage sending wire and all the hoses? The back of the tank has to come down first.
PostPosted: Fri Jan 04, 2013 9:15 pm
no i have not disconnected the hoses and wires. its pretty hard when the bed is on
I'm workin' on it
SBC
PostPosted: Fri Jan 04, 2013 9:25 pm
It isnt going to come down till all those are off, there are no slack in them.
PostPosted: Fri Jan 04, 2013 9:32 pm
ok, ill go pull them off and report back
I'm workin' on it
SBC
PostPosted: Fri Jan 04, 2013 9:41 pm
You will need some needlenose pliers to get the clamps off.
PostPosted: Fri Jan 04, 2013 9:44 pm
This is going to be a long night.
PostPosted: Fri Jan 04, 2013 9:49 pm
it will be a very long night! if only i could take off the bed quickly
I'm workin' on it
SBC
PostPosted: Fri Jan 04, 2013 9:53 pm
Forget the bed already, I have pulled these tanks in a half hour many times, shorter time then you have responding to this post.
PostPosted: Sat Jan 05, 2013 2:27 pm
ok, this is my first luv, and is very rusty. i'm sorry if i'm bothering you by figuring out how too drop the tank. ive got all the bolts out, the fuel lines and sending wire but it still isnt coming out. i can jack it up, and itt is loose but wont come out. once this thing is out im puttig in my fuel cell
I'm workin' on it
SBC
