It is currently Sun Jun 07, 2026 6:53 am
 Post subject: saggy door hinge fix
PostPosted: Mon Dec 03, 2012 7:11 pm
My door hinges are a bit saggy. I replaced one but it's not much better, has anyone tried taking the pin out to put some bushings in? I searched and didn't come up with much.
1980 LUV 4wd 1.8, 31's, 3" body lift, weber 32/36, header, fakemaster, project in progress
1989 Isuzu Pickup 4wd 2.6, 2.3 head, weber 38, header, flowmaster, 31's, DD/light wheeler
1989 Camry, the race car
1968 Ford Fairlane Fastback, next in line
 Post subject: Re: saggy door hinge fix
PostPosted: Mon Dec 03, 2012 8:38 pm
i got lucky and got a good one from ctmandu... before that i have heard suggestions of putting in a bushing or boring the pinhole slightly and putting a bigger pin in.
PostPosted: Tue Dec 04, 2012 11:16 am
I had the hood hinges on my El Camino rebuilt and they came out really nice, cost more than repros but I heard those fail after a few years. This guy also does door hinges and says he will do them for any type of vehicle.
http://www.hoodhingerepair.com/
PostPosted: Tue Dec 04, 2012 7:14 pm
I took the upper hinge from a passanger door that closed well and just flipped the direction it goes.
Perhaps for the lower hinge you could take the pin from passanger side and put that in the exsiting lower hinge.
PostPosted: Wed Dec 05, 2012 7:54 pm
search door hinge fix
PostPosted: Sat Dec 08, 2012 4:06 pm
I'll try an drill em out next time I take the doors off, then. Thanks
PostPosted: Mon Dec 10, 2012 8:26 pm
Weld it solid and drill it out. Or weld it out and grind it down. I noticed my driver side door is sagging the other day and this was my initial thought. Havent inspected it much.
1980 4x4
PostPosted: Wed Dec 12, 2012 10:40 pm
I'd rather oversize it and go with bushings, they are replaceable and less dealing with proper pin alignment that way
